Wyoming1 wrote:Understood. Just interested in what other 170 owners have as their BEW.
redacted wrote:Mine on 8.50's is 1420. On 29's it's 1444.
Lyc O-360 Avcon conversion, MT prop. 175 wings, sportsman cuff, AK bushwheels tailwheel. Def some pounds added on, I think the sportsman kit is 20#
Wyoming1 wrote:redacted wrote:Mine on 8.50's is 1420. On 29's it's 1444.
This is interesting to me. I have the same engine conversion (170A model), Hartzell prop, standard wings and wheels and am at 1270#. I took the back seat out and dropped another 31# putting me at 1239#. Which MT prop did you put on? That is definitely on my wish list as are the 8.50's.
Thanks for the input.
GAHorn wrote:Joe, are you certain it was an MT prop with the lag screw problem… not an Aeromatic..?
I ran into a similar problem with NTSB on another accident in which a 172 crashed in a canyon. NTSB blamed the problem partially on the fuel selector valve (same type as the 170B) which had the O-ring and the ball-valve reversed…claiming it shut the fuel Off and therefore resulted in engine-stoppage.
I contacted the lead investigator and pointed out that, while NTSB is correct that the IPC shows the incorrect order-of-assembly of the valve parts….. the incorrect assembly will result in Failure of the valve to Shut Off fuel flow….NOT to result in failure to allow fuel flow as NTSB claimed.
The lead investigator had no interest in correcting the error in her report.
(This matter was addressed by me in a Fuel Valve Rebuild article published in the 1st Qtr 2011 “The 170 News” found/downloadable here: https://cessna170.org/download/24/170-n ... r-2011.pdf
rnealon1 wrote:I had my '54 170B with stock C-145 engine and no major modifications weighed a few years ago:
BEW: 1330 pounds
CG: 39.70"
This was within 14 pounds and 1" of the calculated BEW and CG, based on the original Licensed Empty Weight.
Bob
Users browsing this forum: MikeAndBella170 and 25 guests
