Control Wheel panel bushing
Does anyone have a good source for the panel bushings for the control wheel yoke shaft and universal knuckles? New member. just purchased 4628C Thanks, Jim Andem
- Ryan Smith
Re: Control Wheel panel bushing
I saw her at Oshkosh. Was that you that flew it in?
That airplane was based about 75 miles from me for many years. Always was a nice airplane. Congratulations on the new purchase!
About forty years ago, a good friend and machinist made me some new ones out of nylon, have held up great. Small job for a good machinist. Also made some seals for the pull out vents from the same material. The vents are tight and stay where you put them. Any good little local machine shop could do this.jandem wrote:Does anyone have a good source for the panel bushings for the control wheel yoke shaft and universal knuckles? New member. just purchased 4628C Thanks, Jim Andem
The "balls" are available from Univair http://www.univair.com/search.php?search_query=0411224
Wag-Aero used to sell teflon versions of these for much cheaper but doesn't seem to offer them anymore.
McFarlane sells the universal joints http://www.mcfarlane-aviation.com/Produ ... goryID=268
You can start with a 1 1/2" Delrin ball from McMaster-Carr p/n 9614K39 $3.53 each. Just needs a 3/4 inch hole drilled through the middle. Owner produced part.
Aircraft Spruce should have both as well, not sure how the price compares
Fred L. Mahan
51 C170A N1289D
51 C170A N1289D
jandem wrote:?..........New member. just purchased 4628C Thanks, Jim Andem
Jim-
Welcome to the world of C-170 ownership! I'm sure you have already decided what a great airplane you have selected. You will find a whole group of helpful folks in this association that will provide you with just about any advice you are looking for (and sometimes advice you aren't looking for) .
To get the most out of owning your 170, joining TIC170A will pay returns much more valuable than the cost of membership. I encourage you to consider joining and we all look forward to meeting you and getting to know you in the future.
Jim already joined. But like many who join, he either missed or did not understand that he must ask to have his forum privileges upgraded. In his case as I have done for others, I've connected the dots from his post lacking an upgrade and his application for membership. And and you can see his privileges have been upgraded. Wish this process was automatic but it is not.hilltop170 wrote:To get the most out of owning your 170, joining TIC170A will pay returns much more valuable than the cost of membership. I encourage you to consider joining and we all look forward to meeting you and getting to know you in the future.jandem wrote:?..........New member. just purchased 4628C Thanks, Jim Andem
Thanks for all the great replies....outstanding. Nope, that was previous owner at Oshkosh. Calling sources about 'joints and balls' ....the ones in 28C are tired but airworthy. Yes, I did join 170 association but was unaware of 'upgrade' requirement...thanks much for doing that ! Jim N4628C
- Patrick Phillips
I like the plastic ball better .....Anybody making these control wheel bushings these days ?
These balls are the best material I could find based on advertised specs, I have no actual experience with them. Any good machinist can center-drill the correct size holes for you.
- wabuchanan
I posted about the Delrin balls just this last September, with pictures if you would like to take a look at the discussion Jim.
It is here: viewtopic.php?f=24&t=15342
1950 170A N5776C SN:19730
Welcome Jim thanks for joining and good luck with your machine
I've been unable to find any in ball shape, but Delrin AF is what you want -- it's "Teflon-filled Delrin", meaning it's got particles of PTFE uniformly mixed into the plastic. Very low friction. But regular Delrin is perfectly suitable for the task.
