Master cylinder mounting brackets
alaskan9974
Post by alaskan9974 »
My right side brackets broke on the 170, where the master cylinder bolts to the tunnel. I show 0411549 and 0411550 as the replacement, I see reports of either aluminum or steel, but they have the same p/n. Anyone bend these from .040 steel or similar? My bracket is in pieces unfortunately.
'53 B-model SN:25712
edbooth
Re: Master cylinder mounting brackets
Post by edbooth »
alaskan9974 wrote:My right side brackets broke on the 170, where the master cylinder bolts to the tunnel. I show 0411549 and 0411550 as the replacement, I see reports of either aluminum or steel, but they have the same p/n. Anyone bend these from .040 steel or similar? My bracket is in pieces unfortunately.
I fabricated brackets out of SS sheet about 35 years ago, just used the broken one as a pattern. Still going strong.
