Page 4 of 4
Re: Low Oil Pressure
Posted: Sun Aug 01, 2021 4:32 pm
cessna170bdriver wrote:GAHorn wrote:I’ve seen two pressure transducers leak over the years in various installations. There’s a diaphragm inside that can eventually fail and they leaked thru the phenolic/base seal. (tho’ it was only messy… didn’t dump the oil overboard.)
Only two (in how many years?); that’s a much better record than the copper line.
They were the only ones I was aware of being installed and were discovered while looking for the oil leaks.
Posted: Wed Aug 04, 2021 10:35 pm
by IP076
George,
Last Thursday I took your advice and warmed the airplane up in the pattern. I don't recall for sure, but the air temp was somewhere in the upper 70s. Here's a few pics:
Initial Engine Runup at 1700 RPM:
Climbout at 2500 RPM:
Downwind descending:
Taxiing:
Climbout at 2500 RPM, second pattern:
More pics in subsequent post.
Posted: Wed Aug 04, 2021 10:42 pm
by IP076
Continued:
Taxiing in again:
Climbout again:
On downwind:
Taxiing in, final time:
That last picture taxiing in shows the oil pressure basically at the stop, with about 195-200 degree temperature. Even at the upper RPMs, 2500 or better, it doesn't seem to make 30psi.
I had to leave town due to an emergency. When I get back I'll be (finally) replacing the gauge to check it's accuracy. After that, I'll yank the screen and look for anything new. Apparently the postal service delivered my oil sample via carrier pigeon. Last I checked Blackstone didn't have it yet, I'll call again tomorrow.
If there's nothing obvious after that, I'd have to guess it's the oil pump or bearings...I'd assume I'd see that in the oil, but otherwise not sure how to verify such.
Anyways, thanks again to the forum members for continued help.
Posted: Thu Aug 05, 2021 2:52 am
While those readings are concerning…. until we know the gauge is accurate….we don’t know much. (Hoping that gauge is wrong.)
Posted: Thu Aug 05, 2021 3:50 am
by IP076
GAHorn wrote:While those readings are concerning…. until we know the gauge is accurate….we don’t know much. (Hoping that gauge is wrong.)
You and me both. I should be back in town next week and plan on hooking a different gauge up to verify. I’ll let you know what comes of that.
Posted: Thu Aug 05, 2021 9:48 am
One encouraging thing is that looking at your temp gauge, the readings look normal. Maybe you know different ie your have lower, the same ,or higher oil temps given conditons.
When I wiped out my bearings, oil temperature climbed to near over temp conditions and that is a lot considering the Cub oil temp never got over 140°.
Posted: Fri Aug 06, 2021 2:43 am
by c170b53
Looks like you’re only using one half of that oil gauge if that, maybe a new lower range gauge might work better for you.
Posted: Tue Aug 24, 2021 11:34 pm
by IP076
Hey guys, been away from the airplane for work and life stuff for a month or so, unfortunately.
I did make it back to this project today, so here's the latest. I did get the oil analysis back, nothing out of the ordinary, good comments, no evidence of any metal being made. I did check the screen again today, no metal...hasn't been run much, but figured I'd check it.
I hooked the existing oil pressure gauge up to the air compressor, which has a gauge on the regulator and a secondary pressure gauge I had connected to it. I compared each at 20, 30, 40, 50, and 60 psi.
Here's some pics:
20 PSI @ Compressor:
20 PSI @ Gauge:
30 PSI @ Compressor:
30 PSI @ Gauge:
40 PSI @ Compressor:
Continued in next post...
Posted: Tue Aug 24, 2021 11:42 pm
by IP076
Continued from above:
40 PSI @ Gauge:
50 PSI @ Compressor:
50 PSI @ Gauge:
60 PSI @ Compressor:
60 PSI @ Gauge:
As you can see in the lower PSI pics, the margin of error is around 10 PSI and shrinks to maybe 4-5 PSI at the higher end. All of this assumes that the two gauges on the compressor end are fairly accurate of course.
Interesting find. I ordered a replacement gauge, figured it was worth a shot. As mentioned above, I got one that didn't go as high...seems excessive to have a scale to 120 PSI in this installation.
Thanks again for your help in diagnosing the issues here.
