Gas cap chain source? Wing sump sizing?
oldtrucksrule
Post by oldtrucksrule »
Couple of fuel questions, I'm still trying to get my '48 170 flying.
The gas cap chains were very rusty, I'd like to replace, does anyone have a source? The part number came up with nothing and the description of Acco American Pattern was too vague.
My wing sumps are leaking I'd like to replace the o-ring/seals. I tried loosening with an open end wrench with no luck (did not want to strip). I know they make a tool , my question is, what is the size I would need? I'm away from my plane but, my memory has me believe it was 9/16"
Re: Gas cap chain source? Wing sump sizing?
Some ideas:
I don’t know about the ‘48 gas caps, but the caps on my A-model have sash chain type of chain holding them on with safety pin style connectors.
https://www.univair.com/tires-wheels-br ... 015-chain/
https://www.univair.com/hardware/pins/v ... gLvu_D_BwE
Monarch caps use the small ball chain like used on key chains. They fall apart easily and I would not use them on gas caps.
oldtrucksrule
Hilltop, that is exactly what I need. Thanks!!!
