Tire STC?
voorheesh
Re: Tire STC?
Post by voorheesh »
Sorry, I didn’t realize you were in Canada but the basics still apply. Maybe a Canadian member might have some advice. In any case you need to verify how this works in your country. You are on the right track.
Re: Tire STC?
Our MX Library has a 337 in which is issued “Field Approval” for the 8:50 X 6 Tires on a Cessna 170. Although the exact wheel was not specified…it clearly is a Cleveland wheel assy because the parts necessary to provide brake-disc clearance are Cleveland PNs.
This might encourage your A&P/IA to seek identical approval from your FSDO…or at least feel better about recording the work.
Here’s a link to the MX Library copy: viewtopic.php?f=40&t=7082
reecewallace
Re: Tire STC?
Post by reecewallace »
Well, I took the FA Dodge letter and other documents to my mechanic, but field approvals and mechanics signing off on alterations is not a thing in Canada. It has to be approved by Transport Canada from the top down.
I'll follow up with TC and see what my options are. Thanks for all the help.
- Reece
1956 Cessna 170b
Nanaimo, BC Canada
