Fellow 170 caretakers,
I just replaced both seals in my pull starter motor (170A). As I look at it now I think I may have installed the one around the pinion gear backwards (brass colored one in the photo). I have the “cup” portion of the seal towards the motor and I’m wondering if I should have done it the other way to keep oil out of the motor. Any help is appreciated. (I’ll probably see my A&P tomorrow, but I’d like to fix it now if it is needed.)
Thanks,
Starter Seal, Did I Install Backwards?
- dstates
Re: Starter Seal, Did I Install Backwards?
Both cups should face the engine. You want to keep oil inside the engine.
- dstates
GAHorn wrote:Both cups should face the engine. You want to keep oil inside the engine.
Yeah, that was my thought. I realized it right after I pressed it in…. Looks like Fresno Air Parts will get another order from me.
