Magneto Malfunctions in-FLight
Posted: Thu Jan 19, 2023 3:16 pm
Aviation Consumer has an article I read this morning which is a good review for us about magnetos. I recommend it for reading.
I would like to Add a point I feel which was overlooked …. in the “inset” article ..(the article within the article)…. it was pointed out that IF you experience an In-Flight failure or malfunction of a magneto… that you are “hereby authorized” to shut that bad mag OFF.
I don’t believe anyone needs to be “authorized” to disable malfunctioning equipment…but I Do want to point out that even a Short Period of continued operation of a magneto with a failed or stripped distributor-gear In-Flight…. is bad. Very Bad. This is because the magneto with a stripped distributor gear will stop distributing the spark to the proper spark-plug. It will likely stop the rotor at whatever position the rotor is when the gear stripped…. in other words…still sending any sparks to that one cylinder it’s pointed-at…. This means the still-rotating magneto …still being driven by the engine….. is still making sparks…. and that rotor is still giving ALL of it to that one cylinder… regardless of where the piston is in the four-cycles of engine-combustion.
A cylinder …fully charged with fuel/air mixture….at the beginning of it’s compression-stroke can receive an ignition-spark….several of them in fact…. which during 2500 RPM cruise is getting that spark 1250 times each minute…. in other words 20-times Each Second…. that you sit there in the cockpit startled that the engine has become “rough”.
I doubt I need to help anyone visualize what a pre-mature explosion inside a cylinder which has a piston coming UP on a compression-stroke can do to the engine.
Bottom line: If you get rough mag in-flight…shut that mag OFF …NOW… and look for a place to park it for maintenance. (BTDT)
Hope this helps.
https://www.aviationconsumer.com/mainte ... ct-repair/
Hope this helps.
