Airbox repairs-What alloy?
Vertical
Post by Vertical »
Anyone know what the 170b airbox is made from? 4130? Mild steel? Galvanized? Mix dependent on component?
Appreciate it if someone has experience on this. Need to do a small weld repair.
Thanks!
schnepel
Re: Airbox repairs-What alloy?
Post by schnepel »
Mild steel, I don’t see a need for 4130 on the box. Galvanized metal would produce dangerous gas in the event of a fire. I’ve brazed on box components (lower heat that helps minimize warping the metal) in the past with good results.
Vertical
Post by Vertical »
Thanks for the feedback. Also the first post in almost 10 years? Welcome.
schnepel
Post by schnepel »
Vertical wrote:Thanks for the feedback. Also the first post in almost 10 years? Welcome.
:D
