Where’s the current ‘go to’ place for seat rails? Still McFarlane? Annual planning underway and that may be on the list this year.
(Or maybe someone has a couple sets they need to get rid of?)
Seat Rail Replacement
- Kyle Wolfe
Re: Seat Rail Replacement
Kyle
54 B N1932C
57 BMW Isetta
54 B N1932C
57 BMW Isetta
- jcsand
Has anyone used the approved screws to attach the seat rails rather than rivets as advertised at McFarlane Aviation when replacing seat rails?
The McFarlane seat rails are slightly “beefier” than OEM. https://www.mcfarlaneaviation.com/produ ... ails/faqs/
The website has some illustrations as well as a link to the Special Airworthiness Information Bulletin CE-90-03R2 https://www.mcfarlaneaviation.com/media ... 0-03r2.pdf permitting screws instead of rivets.
- DaveF
I have used screws for the larger diameter fasteners at the ends of the rails. You just have to spot-face the locations on the rail to make sure the screw heads have a square seat. This picture shows the old rail I used for practice and the new rail freshly spot-faced.jcsand wrote:Has anyone used the approved screws to attach the seat rails rather than rivets as advertised at McFarlane Aviation when replacing seat rails?
- cessnut
The only place I have ever installed screws is at the ends where they tie into the bulkheads, when the rivet holes were questionable. I have seen them installed with screws and thought it looked cheap. If you can reach in and install a nut and washer, why not just buck a rivet? Since it requires a structural screw, it seems you would have to upsize all your holes to accommodate a #8 screw.
McFarlane rails may be beefier, but they don't seem to have the strength of the originals. I once demonstrated this by taking a misdrilled one and bending it around my knee.
- jcsand
Thanks for your time/thoughts regarding screws vs. rivets in the seat rails. I think that I'll go with rivets.
- cfzxo
I wonder if the older seat rails have work hardened over time?cessnut wrote:The only place I have ever installed screws is at the ends where they tie into the bulkheads, when the rivet holes were questionable. I have seen them installed with screws and thought it looked cheap. If you can reach in and install a nut and washer, why not just buck a rivet? Since it requires a structural screw, it seems you would have to upsize all your holes to accommodate a #8 screw.
