Page 4 of 4
Re: Seat Rail Replacement
Posted: Fri Feb 23, 2018 4:07 am
by Kyle Wolfe
Where’s the current ‘go to’ place for seat rails? Still McFarlane? Annual planning underway and that may be on the list this year.
(Or maybe someone has a couple sets they need to get rid of?)
Posted: Sat Mar 11, 2023 2:06 am
by jcsand
Has anyone used the approved screws to attach the seat rails rather than rivets as advertised at McFarlane Aviation when replacing seat rails?
Posted: Sun Mar 12, 2023 1:09 pm
The McFarlane seat rails are slightly “beefier” than OEM. https://www.mcfarlaneaviation.com/produ ... ails/faqs/
The website has some illustrations as well as a link to the Special Airworthiness Information Bulletin CE-90-03R2 https://www.mcfarlaneaviation.com/media ... 0-03r2.pdf permitting screws instead of rivets.
Posted: Sun Mar 12, 2023 7:59 pm
by DaveF
jcsand wrote:Has anyone used the approved screws to attach the seat rails rather than rivets as advertised at McFarlane Aviation when replacing seat rails?
I have used screws for the larger diameter fasteners at the ends of the rails. You just have to spot-face the locations on the rail to make sure the screw heads have a square seat. This picture shows the old rail I used for practice and the new rail freshly spot-faced.
Posted: Sun Mar 12, 2023 11:19 pm
by cessnut
The only place I have ever installed screws is at the ends where they tie into the bulkheads, when the rivet holes were questionable. I have seen them installed with screws and thought it looked cheap. If you can reach in and install a nut and washer, why not just buck a rivet? Since it requires a structural screw, it seems you would have to upsize all your holes to accommodate a #8 screw.
McFarlane rails may be beefier, but they don't seem to have the strength of the originals. I once demonstrated this by taking a misdrilled one and bending it around my knee.
Posted: Mon Mar 13, 2023 12:31 am
by jcsand
Thanks for your time/thoughts regarding screws vs. rivets in the seat rails. I think that I'll go with rivets.
Posted: Wed Mar 22, 2023 5:42 am
by cfzxo
cessnut wrote:The only place I have ever installed screws is at the ends where they tie into the bulkheads, when the rivet holes were questionable. I have seen them installed with screws and thought it looked cheap. If you can reach in and install a nut and washer, why not just buck a rivet? Since it requires a structural screw, it seems you would have to upsize all your holes to accommodate a #8 screw.
I wonder if the older seat rails have work hardened over time?
