Wanted: 0300 complete Exhaust System
Where TIC170A members may list items for sale or trade or make wants known.
Forum rules
Guests and forum participants are welcome to view posts in this area but one must be TIC170A member to post an ad here - -Why Join the TIC170A - - How to Join the TIC170A
Postby ronair » Thu Sep 22, 2022 4:43 pm
I am in need of a complete exhaust system and heat muffs for an 0300. Call Ron 705-499-0251
ronair
Re: Wanted: 0300 complete Exhaust System
Postby eskflyer » Thu Sep 22, 2022 5:43 pm
i have a complete set on a o300D from a cessna 172.
eskflyer
Postby Bruce Fenstermacher » Thu Sep 22, 2022 7:36 pm
FYI The mufflers for a later 172 are not the same as for a 170. They are a little bit larger and usually don't fit under the nose bowl without blisters in the bowl. They may be the same if the 172 they came from is a '56 or '57
Email:
N7A '49 170A -More original than most making folks GREEN with envy
N42532 '45 J-3 Clipped Wing Cub
Postby canav8 » Fri Sep 23, 2022 11:32 am
The 172 Hanlon Wilson cans are larger exit port. They are 2.25 diameter instead of 2 inch. Different part numbers. No they are not higher performance either. D
52' C-170B N2713D Ser #25255
canav8
Postby Bruce Fenstermacher » Fri Sep 23, 2022 12:33 pm
Bruce Fenstermacher wrote:FYI The mufflers for a later 172 are not the same as for a 170.
To clarify further, there is no difference between a muffler system for a C-145 or any model of 0-300. Assuming the OP wants to find a Hanlon-Wilson system here is what they would be looking for depending on what year/serial number 170 they have.
If you have a '52 serial 25372 or prior, the right and left muffler assemblies which includes all the clamps, exhaust inlets, heat shroud and hardware, are exact duplicates. There is a different left and right exhaust stack however.
If you have a '53 serial 25373 or later, the entire muffler system is the same as that for serial 25372 and prior except for the right hand muffler and head shroud parts.
An entire muffler system from a 172 serials 28000 to 47746, if it uses the original part numbered parts, is the same system as that in a '53, serial 25373 and later 170B. Muffler systems found on 172s after serial 47746 are not the same as the earlier system in that the diameter of the muffler cans are bigger and as reported the exhaust stack diameter is bigger and perhaps some other differences which might interfere with direct installation on any model of 170.
Email:
Postby Bruce Fenstermacher » Fri Sep 23, 2022 12:45 pm
As TradeMart listings get deleted in time, please direct any further posts regarding the differences between Hanlon-Wilson exhaust systems to this thread:
viewtopic.php?f=24&t=16221
Email:
Return to The TradeMart
Who is online
Users browsing this forum: No registered users and 1 guest
