Page 2 of 2
Re: Questions about Logbook/Equipment/Documentation
Posted: Tue Sep 17, 2019 1:48 pm
Have your inspector look at it and make a log entry.
Posted: Tue Sep 17, 2019 2:49 pm
by c170b53
It appears that just the instrument panel metal has been replaced. Typically .125 aluminium sheet replaces the original .125 to pretty up the old gyro holes.
Posted: Tue Sep 17, 2019 10:23 pm
If you look under the panel at the center control T, this is the structure that the aileron cables wrap around, and it looks like a T rather than a Y. It is likely original. Most center stack changes require a later Y design so the radios in the center are not hit by it.
Posted: Thu Sep 19, 2019 3:10 pm
by cessna170bdriver
I made a new panel for ‘98C and had it approved with a logbook entry. I kept the uncut original and its overlay for anyone who might want to put it back original.
Posted: Thu Sep 19, 2019 5:17 pm
by rnealon1
Thanks guys,
There is a logbook entry for the panel installation. It says "installed new panel". Once I am sure that there was no center control modification I think I will not worry about this one since at least I know when and where it was installed and it is (poorly) documented.
Thanks again for all the help.
Bob
