trim
T. C. Downey
trim
Post by T. C. Downey »
Power off in the decent, when you roll your trim all the way nose up, at what speed does it settle out at?
lets say you have 2 aboard, with a half bag of fuel.
ghostflyer
Re: trim
Post by ghostflyer »
About 65 kts.
T. C. Downey
Re: trim
ghostflyer wrote:About 65 kts.
Knots ?
74.5 MPH. :)
cowman57
Re: trim
Post by cowman57 »
I'm no expert on flying the 170, as I've only had my B model since last fall, but basically I don't even use my trim. I found that flaps applied when power is reduced keeps the plane in trim.
fishdoc
Re: trim
Post by fishdoc »
The 'A' model will give you an arm cramp if you don't use it... :wink:
1952 170B (with the sexy rounded tail)
Re: trim
T. C. Downey wrote:Power off in the decent, when you roll your trim all the way nose up, at what speed does it settle out at?
Which model 170?
T. C. Downey
Re: trim
Which model 170?
There is only 1 model 170, the rest are 170-"A"s or 170-"B"s
George I am surprised you didn't know that :)
Poncho73
Re: trim
Post by Poncho73 »
Just wondering...why would you need to roll your trim "all the way up"? Not being smart, but what is the issue? FYI, I've never needed maximum trim, in either direction, including max loads on my 48
Re: trim
170A, O-300-D, 76-55 prop, 2 people, 18gal, idle power, full nose up trim, stabilized descent from 3500'msl;
Flaps up, 67mph, 600fpm descent
Flaps down, 65mph, 800fpm descent
Re: trim
Which model 170?
According to the TCDS there are three models; Model 170, Model 170A, Model 170B.
ghostflyer
Re: trim
well just tried the scenarios given and it's still 65kts. But I have a different engine up front and a the aircraft weights a a bit more . It was a stabile descent at just under 500 ft a min .
Re: trim
Which model 170?
OK then,..... what size bag? :roll:
T. C. Downey
Re: trim
gahorn wrote:[
OK then,..... what size bag? :roll:[/quote]
I'll give ya a pass, for the short answer.
Re: trim
Well, I did it today JUST FOR YOU, Tom.... :wink:
...half fuel, Jamie and I, zero flaps, full nose up trim, idle power....it settled at 60 mph indicated. (1K MSL, 90 degrees F, baro 30.10)
