camshafts, and or camshaft sets with lifters
across
Post by across »
anyone put a new cam, and lifters in the 0-300/ C-145 lately ? like to go with new parts if they are available, my superior web site does not show a cam part number, lots of other parts,, no cam...
lowNslow
Re: camshafts, and or camshaft sets with lifters
Post by lowNslow »
Fresno Air Parts carries most anything you would need for an C145/O300. They are however very old school so have no website.
There phone is (559) 237-4863
I found mine through Aviall, but that was in 2006...
There were a few changes in the cams over the years. The early cams had more "pointy" lobes than the later which were more rounded. This gives the later cams a bit more valve overlap and supposedly improved power at/above 2500 RPM. Without disassembly you can usually tell if you have an early or late cam by the way it idles.
Early cam at 600 RPM gives about 10" manifold pressure (near S.L. of course)
Late cam at 600 RPM gives about 15" M.P.
straight tail 172
Post by straight tail 172 »
I was able to order a new camshaft from Continental for my 0300A rebuild a couple of years ago. 125 on the engine and going strong. Six new ECI cylinders, lifters, camshaft and other work, helps it run like new.
Metal Master
Post by Metal Master »
TCM Teledyne Continentals web site has an interesting feature if you have not been there lately. On the tool bar at the top of their web page is a link called support materials a search of complete engine parts lists are available. All service bulletins are available free no membership. The only thing you can not link to are overhaul manuals. And they do not have C series engines listed. ie C145, C-85 etc. There is also a parts supersedure listing so that if you know a current or later part number it will list the part numbers that that particular part superseded. to a point. Sometimes Superior Air-Parts lists their PMA part number by the superseded part number. As far as I know Superior Air-Parts does not manufacture a cam shaft for O-200-0300 engines
On TCM's web site you can do a service bulletin search by engine by model a very useful tool.
http://www.continentalmotors.aero/
T. C. Downey
Post by T. C. Downey »
Metal Master wrote: The only thing you can not kink to are overhaul manuals. And they do not have C series engines listed.
Simply because the designation of the C-145 was changed to 0-300-A Use that data for all C-145 issues.
the C-65-C-90 are no longer supported.
My customer just bought a complete cam kit from Aircraft Specialities in Tulsa OK. he was required to buy each part number in the train. (cam-lifter body-hydraulic unit-cup- and clip ring.) but they had the parts in stock.
