I'll be mounting my new tires tomorrow under supervision of a TC170A member and A&P. Can anyone tell me the torque values for the wheel bolts and brake caliper bolts? I have Cleveland wheels and Cleveland double puck brakes.
Thanks, JP White
Torque Values
Torque Values
C170A N1714D
My First Airplane!
My First Airplane!
- mit
Re: Torque Values
Thanks for the info guys. Looking forward to my first tire change this morning. You must be an airplane nut to look forward to this!
JP
JP
C170A N1714D
My First Airplane!
My First Airplane!
- gfeher
Re: Torque Values
The Cleveland Technician's Service Guide has the same information you are looking for except in a simpler, shorter format. Here is a link to it (I hope I've done this right):
http://www.parker.com/literature/Aircra ... 001-10.pdf
Gene Feher
Argyle (1C3), NY
Argyle (1C3), NY
Re: Torque Values
Yes indeed, very bad. This may be the most common mistake that mechanics make (owner mechanics AND A&P mechanics). Not just brake calipers, but tightening/torquing in general. I've watched behind and inspected behind many very experienced mechanics. Over torque, by a very large margin, takes up the largest chunk of the pie chart in mechanic mistakes. Most folks, including myself sometimes, forget about the leverage the tool offers.Aryana wrote:..........over torquing the steel bolts in the thin aluminum caliper is bad news!........
Del Lehmann
Mena, Arkansas
Mena, Arkansas
