Master Relay or Solenoid, Battery contactor
Re: Master Relay or Solenoid, Battery contactor
The big load is starter current, several hundred amps. Everything else is in the noise.
pojawis
Post by pojawis »
Very good and timely information, for me at least. THANKS. Saved a bunch of time on my part.
Found two solenoids from Wicks Aircraft. One is listed as a starter intermittent solenoid, p/n 24037, $19.95. The other as a master continuous solenoid, p/n 24115, $23.55. The descriptions cover both and indicate these are Cole Hersee solenoids. No indication of PMA. I have not verified that this is a correct replacement for the 170...
pmel22
Post by pmel22 »
I replaced my old relay with a sky-tec sts-m12 in June, and it has now failed. I put in a call to Hartzell lets see what they have to say.
pmel22
Post by pmel22 »
Caution there is a service bulletin on the STS-M12, and it requires replacement.
lowNslow
Post by lowNslow »
Here is the link to the aforementioned SB. Tried to upload it but it exceeded the 1MB limit.
http://skytec.aero/wp-content/uploads/2 ... SB-072.pdf
Ryan Smith
Post by Ryan Smith »
Is there a source for the clear plastic covers, or are these unobtanium?
You can find them right next to assist straps and instrument overlay rings. Keep you eyes open I've found all three.
Ryan Smith
Bruce Fenstermacher wrote:You can find them right next to assist straps and instrument overlay rings. Keep you eyes open I've found all three.
Any tips would be appreciated. It doesn’t appear that it has a part number?
I’ve lost track of how many years my master contractor cover has been missing. It doesn’t seem to be a problem.
