Empty Spot in Instrument Panel
MoonlightVFR
Post by MoonlightVFR »
I am going to take a few new passengers up. Never been in small GA plane.
A/C is 54 C170B, S N 25433 mfg JUly 1954.
I want new passengers to Enjoy flight and not worry about missing instruments in panel.
At far right of panel above the glove box I have two (2) of the smaller mounting holes.
My question to the forum is What would normally go there?
I do not need any additional instruments.
Are false filler panels available?
G
gradyb, '54 B N2890C
Re: Empty Spot in Instrument Panel
Grady,
Although no simpler part could be made for your plane you can still buy the genuine Cessna cover plate, p/n 0713200-7, from Preferred Air Parts. A cheaper alternative would be a cover from Aircraft Spruce. Take a look at figures 44, 77, 79 and 80 in the IPC to see that optional instruments included a suction gauge, CHT, manifold pressure gauge and carburetor temperature gauge.
Often for new passengers a sense of control will help eliminate the fear of flying. One idea might be to install a dummy ON-OFF switch in a blank hole and label it “MCAS”. After takeoff initiate phugoid ... :twisted:
edbooth
Post by edbooth »
A piece of aluminum or plastic and flat black paint works great. :D
Ryan Smith
Post by Ryan Smith »
n2582d wrote:Grady,
You’re a sadistic man, Gary!
That’s why I like the piano key panel...not a lot of holes to worry about filling.
MoonlightVFR wrote:I am going to take a few new passengers up. Never been in small GA plane.
G
Blanked-out inst. holes might raise as many questions as open holes... maybe not tho'. I have a few Cessna Royalite false panels with "blanks" from other airplanes sitting in the hangar attic which you're welcome to. PM me which address to mail them to. When are you planning the flight? If very soon, you might follow Ed's advice.... simply paint a square of aluminum flat-black and slip it behind the panel. You can either mount it permanently or use velcro.
4583C
Post by 4583C »
Grady here is my suggestion to fill one of those holes :lol: Available from Sporty’s
If you’re really a glutton for punishment you could just make a new one. I changed the size and shape of several holes to suit my instruments, and deleted a couple of holes I no longer needed.
More details here
kaufman
Post by kaufman »
Although not the cheapest option, I filled in the last hole (far right side) in my panel with a slip indicator. I found it a very useful and informative instrument for curious passengers. With just a little explanation about coordinated flight and how to " kick the ball to the center" the passenger gets confidence that controlling an airplane is more intuitive than technical, and just plain fun. A more advanced passenger can also serve as autopilot if I want to take a little break, something they cannot do smoothly in turbulence without command of that axis.
