1949 170A Toe in & camber
N9269A
Post by N9269A »
anyone know the toe in and camber for 170A with original gear and wheels ??????????????
gfeher
Re: 1949 170A Toe in & camber
Post by gfeher »
Gene Feher
Argyle (1C3), NY
FredL
Post by FredL »
That information and how to check it, is located in the Cessna 100 series service manual I believe
Zero camber and toe in at 2000 lbs. Heavy duty “contractor” plastic trash bags are a good substitute for greased plates has been often suggested, as the plastic slides/twists readily when the airplane is rolled onto them indicating misalignment.
