1948 C-170 muffler / exhaust cracks
tshort
Post by tshort »
The ragwing is in for annual. Unfortunately I am not participating as I normally do due to the damn virus.
In any case, my friend the A&P found cracks in both mufflers. C-145-2H:
He called Aerospace welding, who he usually uses, and they won't touch them. Is there anyone who repairs these anymore? Is it worth repairing them? If not, where is the best place to source a new exhaust system? It is prime flying season and I hate to keep the plane down longer than I have to...
Thanks in advance for any advice / options.
Thomas Short
1948 C170 N3949V
RV-8 wings in progress
Indianapolis (KUMP)
brian.olson
Re: 1948 C-170 muffler / exhaust cracks
Post by brian.olson »
Thomas - my A&P discovered a crack in one of my mufflers last fall, and after calling around to all of the larger and small companies we couldn't find anyone who would touch them. He successfully welded the crack (near the connecting point of one of the flanges) himself. During a thorough "smoke test" of the exhaust and intake systems we found a crack on the other muffler, and I'm currently using a borrowed muffler until I can get a new set of Hanlon mufflers ordered for the plane. I'm letting the "aircraft repair fund" get back in the black again before I do that.
Brian
1950 170A
N5762C s/n 19716
AWI (Aerospace Welding Inc) is one of our supporters and Charlie Felds up there works with us price-wise also. He is familiar with the conversion to Hanlon Wilson types (which basically use two left-mufflers on both sides) per the approved service letter. (See the Mx Library) http://cessna170.org/forums/viewtopic.p ... son#p61077
DO NOT MIX the two systems. DO NOT USE the 172 system on a 170 or 170-A. (Ignore the website RH muffler setup unless you have a 170-B)
Cfeld@awi-ami.com
800.597.4315
Made sure you tell him the 170 Assoc’n sent you.
That IS NOT a crack in the muffler. It is a crack in the air heat baffle that surrounds the muffler to create hot air for carb heat and cabin heat.
sfarringer
Post by sfarringer »
Bruce Fenstermacher wrote:That IS NOT a crack in the muffler. It is a crack in the air heat baffle that surrounds the muffler to create hot air for carb heat and cabin heat.
Not so sure, Bruce.
Looks to me like the outside half of the heat baffle is removed, and we are looking at the muffler.
Ragwing S/N 18073
edbooth
Post by edbooth »
I don't know a lot about the old pancake mufflers, but it looks like some blind rivets are going through the heat baffle into the exhaust pipes....??? If so, that is not good. :?
tshort
Post by tshort »
The outer part of the heat muff has been removed. This is the inside part.
Does anyone have pics of the inside of this, or an exploded diagram? It is welded around the edges, and riveted to the exhaust pipes. you can see some blow-by where the riveted area is.
Depending on what the inside is like (how the exhaust is “isolated” from the outer material), I would think those cracks could allow exhaust to leak into the heat muff. I am not sure how easy or practical it would be to disassemble this and attempt repair.
I think the plan is going to be swapping this out for the new system mentioned above.
Thomas Short
1948 C170 N3949V
Indianapolis (KUMP)
Thomas,
I'd agree with the plan to swap them out for the Hanlon Wilson mufflers. It's amazing to me that those pancake mufflers have lasted for over 70 years (assuming they haven't been replaced since 1950). Can't let this topic die without an additional CAA-approved SNL. :) Does anybody know how Cessna could determine that it was the length of the tailpipe that was causing the resonance leading to loose rivets? By the way, I like the way you added a heat shield to your engine mount adjacent to the muffler.
Click to Enlarge
Click to Enlarge
tshort
Post by tshort »
So I am communicating with Charlie Feld at AWI; based on the pics of my system, he is not 100% sure the exhaust pipes will exit without cowl modifications. He suggested checking with the Association for input.
Can anyone who has done this on a ragwing comment? Do the pics above provide any reference - I have no idea if the exhaust pipes are as they were from the factory or not. The plane is as it was when I purchased it...
Thomas Short
1948 C170 N3949V
Indianapolis (KUMP)
sfarringer
On my Ragwing, the outlet pipe on one side had to be adjusted to line up with the cowling exit opening. Otherwise it fit fine. I forget which side needed the adjustment.
Ragwing S/N 18073
tshort
Post by tshort »
Thanks for the info; how did you make the adjustment? Did it have to be sent back to AWI?
I was thinking we might have to mod the cowling (cut holes / patch stuff), but if a small mod to the pipe is acceptable that would be easier (and cosmetically better).
Thomas Short
1948 C170 N3949V
Indianapolis (KUMP)
sfarringer
My mechanic cut a wedge shaped sliver out of the pipe to allow the necessary slight bend, and welded the pipe back together. It wasn't a big task.
Ragwing S/N 18073
Your pancake muffler exit pipes look typical.
When these aircraft where new, if you had swapped in a '52 B model Hanlon Wilson system for the pancakes, which is the replacement, the exit holes would have worked. As these cowls are now 70 years old, I'd expect a little trimming out of the exit holes might be in order.
It’s my opinion the better action is to adjust the cowling tailpipe exits. In that fashion, if future exhaust work is required the standard tailpipes will fit. If you change the tailpipes then future work will be required on replacements.
And on a slightly different note... if I planned to alter the standard tailpipes.... I’d first consider saving that money ordinarily spent on standard pipes and applying it toward the “Bartone” tailpipes.
tshort
Post by tshort »
So, the new mufflers have been received and fit up nicely. No issues with the cowl exit.
One issue. The diagram for the Hanlon-Wilson modification references a support bracket. This is #5 in the diagram.
I did not have any bracket / support on the old pancake mufflers. I discussed with Charlie Feld, this is not something they include / fabricate. He thought it might be p/n 0450340-1, which is used on the C-150 system and the C120/140 modification.
What is the correct part here?
Thanks in advance for all the help thus far. I am ready to get flying again!
Thomas Short
1948 C170 N3949V
Indianapolis (KUMP)
