Primer Knob Replacement
Patrick Phillips
Post by Patrick Phillips »
Do anyone know how the primer knob is held on mine is cracked and i want to replace just the knob....Thanks Pat
daedaluscan
Re: Primer Knob Replacement
Post by daedaluscan »
I just broke a perfectly good one by not understanding how it came off. Ended up making a new one on my lathe. Several for sale on ebay.
Charlie
1956 170B C-GDRG #27019
According to some instructs I’ve read (I have not personally done this) Not all knobs come off the plunger.... the nut must be loosened and the entire plunger pulled out of the body.
daedaluscan
On mine the pin should be pulled, and then the knob spins off. There is a pilot hole in the knob male thread. Ill use a spot of loctite on reassembly.
Charlie
Patrick Phillips
ok thanks for the replies .....I kind of thought the little had to come out ....I will try it
We successfully reattached one on ‘97C about a year ago with 5-minute epoxy.
cessna170bdriver wrote:We successfully reattached one on ‘97C about a year ago with 5-minute epoxy.
How do you get it back off..?? :lol:
