New Tailwheel Leaf Springs too thick
Re: New Tailwheel Leaf Springs too thick
The issue still exists, the spring set I purchased from Univair last month (March 2021) would not fit. My Ap/IA spend a lot of time dealing with it.
Might he have tried just replacing a new main leaf with the old spring set ?
Once I was aware of the issue, I gave my IA the option to use just the main leaf from the set, but he has already managed to get the new spring set to fit.
It is virtually impossible....that the entire spring-set needs replacement. The only spring which can fail to hold the tailwheel to the airpalne...is the ONLY spring that is attached to the tailwheel..... and that is the MAIN (lowest) spring.
It is more likely to cause damage to your airplane by forcing-fitting en entire spring-stack than it would to only replace the one spring which really matters in this.
- dstates
I think all 4 of mine needed to be replacedGAHorn wrote:It is virtually impossible....that the entire spring-set needs replacement. The only spring which can fail to hold the tailwheel to the airpalne...is the ONLY spring that is attached to the tailwheel..... and that is the MAIN (lowest) spring.
My tail had the old bracket so I could handle the thicker springs.
- mmcmillan2
Yea, they dun wore out. Is that a tail tie down eyelet?? Where’d ya get it from?
- dstates
Yes, good eyes. It is from Air Repair (their info below). I ended up not using it because I have a Maule tailwheel and it doesn't fit (either orientation) with the cap on the top of the tailwheel (red circled area in picture). I think it only really works with the Scott tailwheel. I think it was $20+ for the part and another $15-20 for shipping.mmcmillan2 wrote: Is that a tail tie down eyelet?? Where’d ya get it from?
Air Repair, Inc 662-846-0228, L-19 PN 0642105, https://www.airrepairinc.com/cessna-l-19.html
I stand corrected. Your previous spring stack was clearly abused above/beyond the ordinary and should have been replaced even earlier.dstates wrote:I think all 4 of mine needed to be replacedGAHorn wrote:It is virtually impossible....that the entire spring-set needs replacement. The only spring which can fail to hold the tailwheel to the airpalne...is the ONLY spring that is attached to the tailwheel..... and that is the MAIN (lowest) spring.
It is more likely to cause damage to your airplane by forcing-fitting en entire spring-stack than it would to only replace the one spring which really matters in this.Maybe I could have kept the smallest one.
My previous comment was made thinking of our recommendation for 500-hour preventive maintenance in ordinary use ...
- dstates
Yeah, I figured I had you with that one. George...GAHorn wrote:I stand corrected. Your previous spring stack was clearly abused above/beyond the ordinary and should have been replaced even earlier.dstates wrote:I think all 4 of mine needed to be replacedGAHorn wrote:It is virtually impossible....that the entire spring-set needs replacement. The only spring which can fail to hold the tailwheel to the airpalne...is the ONLY spring that is attached to the tailwheel..... and that is the MAIN (lowest) spring.
- N3454C
I am planning to replace my tailwheel spring group I purchased from Univair in a few weeks on my '54B model. The IPC shows a couple rubber "pads" (cessna P/N 0442119-1). My concern is (assuming they are original) they should be replaced. I can not find them anywhere for sale. How have others dealt with these pads during leaf spring replacement? Any advise? Thanks.
Eric…don’t you have a 170-B model? …with the large, aluminum “alligator” tailwheel bracket..?? If so, your tailwheel assembly does not use those pads.N3454C wrote:I am planning to replace my tailwheel spring group I purchased from Univair in a few weeks on my '54B model. The IPC shows a couple rubber "pads" (cessna P/N 0442119-1). My concern is (assuming they are original) they should be replaced. I can not find them anywhere for sale. How have others dealt with these pads during leaf spring replacement? Any advise? Thanks.
Perhaps you might wish to review the tailwheel bracket Service Kit Instructions: viewtopic.php?f=40&t=9442
- N3454C
Perfect! Yes, that looks more like it! I will review the service letter, but looks good! thanks!
- redacted
Just installed a new Univair spring set. Bolted up no problem.
Nathaniel Perlman
1952 170B
N2282D S/N 20434
1952 170B
N2282D S/N 20434
- N3454C
Sounds good! planning to do mine next weekend. I hope to have the same results~redacted wrote:Just installed a new Univair spring set. Bolted up no problem.
- BrianW
I have a 55B, and purchased a new main spring U0542106 from univair. My mechanic also said it's too thick to put in with the rest of the stack. If I go ahead and buy the whole pack, will that fit correctly or fit by installing only 3 of the springs?
-Brian
-Brian
