1950 C170A Interior/Electrical Rework
RCoulter
Post by RCoulter »
Figured I would post some before and after pics of the interior and electrical work I did the past eight months while the plane was up north at my Hangar in St Helen. We purchased N9793A October 1st and it was out of annual. So we flew it up north and began ripping and tearing to upgrade the interior, majority of the electrical, as well as a host of other modifications and items. Finished the annual last week and bringing it home in the next week or so as it needs to get to Airventure to be on display at our booth.
I left the PN's and such in this post so if anyone wanted to know what was used they can use it as a reference. Sourcing things sometimes was a challenge, or time consuming, so I figured maybe it could help someone save time doing the same things. Proper kudos to this club for such an amazing community and thanks for answering questions for me along the way!!
LIST OF WORK PERFORMED:
Upgraded Panel Circuit Breaker Layout
- Added all new 7277-2 Circuit Breakers for every circuit besides the 50 AMP ALT breaker
- Added breaker for USB and MAP Lights
- All wiring used was MIL-W-22759/16 wire which complies with current military and anticipated future FAA requirements. Wire size was in accordance with breaker size
- Replaced five standard fuses with 7277-2 Circuit breakers. The circuits were for the AI (AV30), Radio, Beacon, NAV Lights and Landing/Taxi Lights
- Replaced stock CA-2 breaker with new breaker
- New Breaker Panel is an Owner Produced Part
- New Circuit Breaker and Switch Wiring Diagram Completed
Installed all new Switches and Grommets in the Piano Key switch Panel
- Switch P/N: AN3021-1
- Elastic Grommet P/N: AN931-4-7
Installed OPLITE FAA-PMA DUAL COLOR 6 LED MAPLIGHTS
- FAA PMA Approved and Eligible for Cessna 170
Installed MAXDIM MINI DUAL DIM CONTROL UNIT for the Map Lights
- STC, PMA, RTCA/DO-160E SEC 21: RFE Qualified
- Complies to Cessna AD 93-24-15 regarding cockpit fires
Installed Garmin GSB-15 USB Dual Type-A Panel Mounted Charger
- FAA PMA Approved
Installed MC600 series solid wire Vernier Mixture Cable from McFarland
- Mcfarland P/N: MC600-2
Installed new Yoke Shaft Universal Joints
- Mcfarland P/N: UJC-KT-1
Installed new Delrin Yoke Balls
- Owner Produced Part
Yokes were leather wrapped and PTT Button/Support Bracket installed
- Work completed by AviationX.com
- Complies with FAR 25-853 12 Second Burn Test
Installed new Grab Handles
- Parachord handles from Lost River Parachord
- New Titanium handle ends fabricated by Bushliner.com
- Meets FAA Burn Requirements per AC-23A
- Minor Alteration
Installed new Plexi Panel, which is now fully legible and has the proper switch layout for current breaker and switch wiring. (Brian Olson is my hero)
Installed Cessna Ventube
- STC Provided
Installed new Rudder Return Spring
- P/N: 0310196-4
Installed new SCAT tubing and all new clamps in Engine Compartment
- SCAT-8 DUCTING 2" 13FT: Part #: 05-29908-13 - Mfr Part #: OPS8X144
- BREEZE CLAMP 300-32H: Part #: 05-14913 - Mfr Part #: 300 32H
Seat Frames and Seat Upholstery
- Installed Cessna 170B front seat frames that were refurbished by Mario at AircraftSeatFrames.com
- Fabricated New Rear support bar for rear bench seat.
o Owner Produced Part
- Installed new Seat Foam and Upholstery by SportAircraftSeats.com
o Complies with FAR 25-853 12 Second Burn Test
- Weight reduction of 18lbs for the bench seat and combined 16lbs for the Pilot/Co-Pilot seat. 34lbs reduction in total due to removal of seat springs, original covering and foam and then the secondary foam and coverings. After removal of these coverings was finally able to inspect the seat frames to determine they were tweaked and needed to be fully rebuilt. Upgraded to C170B frames which were more robust...and then had them made even more robust
Installed New interior Panel Upholstery
- Covered Door and Rear Side Panels with Ultraleather Material Black and Tan
- New Left and Right Front Panel backing. 0.125” Kydex backing and then upholstered with UltraLeather
o Owner Produced Parts
Installed new Vinyl Flooring With ¼ Soundproofing from SCS Interiors
- Added 6lbs of weight in comparison to stock carpeting. Well worth it for the gain in soundproofing, ease of cleaning the vinyl, as well as no more dirt buildup in the carpet as was found in the carpet that was installed at purchase
Installed Uavionix SkySensor to Right Wingtip
- FAA/PMA Approved
Installed new shielded wire from CB/Switch Panel to Wingtip Uavionix SkyBeacon and SkySensor
- Shielded 20GA 3 CON WHITE WIRE “ M27500-20TG3T14 to the right side Uavionix SkySensor
- Shielded 20GA 2 CON WHITE WIRE M27500-20TG2T14 to the left Uavionix SkyBeacon.
Separated Taxi and Landing Lights so they are on their own dedicated switch
- Used existing wire from Left Side SkyBeacon, which was replaced using shielded wire (above) and connected to Taxi Light and Taxi Light Switch to separate their functionality
Installed BAS Pull Handles
- STC Provided
Installed new Brackett Air Element
- BA6108 for BA2010, BA5110, BA5110A BA6110
Installed new Tempest Oil Filter
- TEMPEST AA48108-2 OIL FILTER
Installed new Silicone Baffling to engine baffles
Installed new Chafe Seal on lower engine cowl
Installed new fuselage to wing seals as well as new gap seals
Replaced stainless screws on the exterior of the aircraft
Panel before installing control cables:
SEATS AFTER FABRICATING
Mario, of aircraftseats.com, who is pretty awesome...upgraded tubing to thicker wall tubing and reworked the seats to near perfection. His brother Daniel at SportAircraftSeats.com did all the seat foam and coverings. Not advertising in any way, but these guys are the salt of the earth and do really good work.
Wanted to thank Brian Olson for his help with the Plexi. Turned out amazing and was a perfect fit. Plus the additional help he provided along the way. What a guy!!
1948 C170 Ragwing (The Silver Cessna)
SN: 18515
Re: 1950 C170A Interior/Electrical Rework
Wow!
What’s Not to LIKE about your Work Product!!
One of the things often overlooked, especially by owners of later models …is the “Straight Wing” of the 170-A model, which is mindful of the Early Days of Aviation. Most (and virtually All early Cessnas) had zero-dihedral wings…. and, in my opinion, provides one of the “classic” look of Early Aviation,….
I like the angle of that photograph which brings that view so nicely.
Thanks for Sharing your Work!
RCoulter
Post by RCoulter »
Much thanks for sure. My first plane and my first efforts working on one. Coming from racing and car restoration…it’s wild to have to source every item in aviation spec.
Was real fun. I thank you for helping me identify the CA-2 breaker.
After Airventure..:another AV30 for the DG, vacuum system removal and some other tweaks. Other than that. She will maintain her roots and whatever most don’t like about an A Model or their springy gear will end up being something I cherish and I’ll adjust my skill set to its characteristics. Someday I’ll get into a more bush worthy plane. But I don’t think I’ll ever let this one leave my hands.
SN: 18515
RCoulter
Post by RCoulter »
Not long after posting this...on July 4th my plane partner ground looped and totaled the plane. Thankfully he and the CFII that was with him were not injured. Was a fun journey and after many months of work, I enjoyed about nine hours and fifty very fun landings. Was some of the most fun hours of flying I had ever had...as it was in my own first plane. Well...co-owned plane.
I learned so much about the 170 during the eight months of work and as I have begun a journey on a new plane N4182V, I am back getting it airworthy again as it was out of annual. Gonna pretty much fly this one and enjoy it for a while. But I did opt to do some slight enhancements during the time of the annual, which is a few weeks from being done.
I also learned a good lesson about upgrades. I will post my thoughts about what I saw witnessing the ground loop, the stock gear, how I felt it flew and what I would have done differently. Ciao for now!
SN: 18515
Steven714
Post by Steven714 »
Were you able to salvage any of the components/work you put into it after it was totaled for your new plane?
RCoulter
Post by RCoulter »
Yes. In the end I will be in a great place with what I was able to salvage. Finishing the annual this week and finally gonna be back in the sky. Did about as much to this plane as we did the last.
Was a stressful process but it worked out good in the end.
SN: 18515
