Tricycle C170
susang777
Yes, I'd be happy to make a web page (or more likely, a set of pages) about vintage/nostalgia 170 things. Again, and as always, with the qualifier that I am doing this only to supplement what TIC170A is doing. If they decide to do this in entirety, I'll be happy to let them.
Since I am already at my quota for my personal web page, I'll probably add it to the c170pics.org site.
http://www.c170pics.org
http://susang777.home.mindspring.com/C170pics/
Send 'em on!
Send 'em on!
-Susan
N3440D
55 170B
TIC170A Member
N3440D
55 170B
TIC170A Member
dkalwishky
Alterfede
Some days ago i saw in internet a pa28 180 tailwheeled, realy really, nice. Do you know if tailwheeling a nosedragger is a lot of work? It would be nice to start doing that here in argentina. And 172 taildraggers deserve to be called (as i´ve seen here in the forum) 170 C!!!!! Because they´re pretty planes without the nose gear.
I havn't done it but a friend is converting a early 150 right now and he says it's more than you think cause you end up fixing other things.Alterfede wrote:Some days ago i saw in internet a pa28 180 tailwheeled, realy really, nice. Do you know if tailwheeling a nosedragger is a lot of work? It would be nice to start doing that here in argentina. And 172 taildraggers deserve to be called (as i´ve seen here in the forum) 170 C!!!!! Because they´re pretty planes without the nose gear.
Doing a Cherokee is really difficult cause the front gear needs to be moved forward and the gear support is internal to the wing. There are a few but not many.
PA22 TriPacers are probably done the most and prabably the easiest cause they are tube and fabric
Alterfede
flyguy
NOSE DRAGGING WONDER
Probably should let this topic die but just saw the picture here on one of our members web site - -
http://www.c170.com/gallery/view_album. ... me=album11
and in digging a little deeper- - -
N-number : N9202A
Aircraft Serial Number : 18963
Aircraft Manufacturer : CESSNA
Model : 170A
Engine Manufacturer : CONT MOTOR
Model : C145 SERIES
Aircraft Year : 1949
Registration Date : 17-May-2000
Airworthiness Certificate Type : Standard
Approved Operations : Not Specified
Don't know if it is still in this configuration or not. The registered owner is one of our members.
N-number : N9202A
Model : 170A
Model : C145 SERIES
doug8082a
susang777
If you'd like to see the photo the new owner of N9202A sent for the picture database, look here:
http://susang777.home.mindspring.com/C1 ... nsort.html
or here:
http://susang777.home.mindspring.com/C1 ... N9202A.jpg
or here:
-Susan
N3440D
55 170B
TIC170A Member
N3440D
55 170B
TIC170A Member
- AWilson
Re: Tricycle C170
The airplane the OP mentioned is my airplane! The thread started in 2003! I have owned her for a little over 2 years. Still looks great! Below is a current picture and what’s probably the picture posted by the OP.
If possible I would really like to find out what the magazine and issue the OP saw it in.
49 A model, serial 18963
Re: Tricycle C170
There was a childhood fairy-tale about an Ugly-Duckling….. which grew up into a Beautiful Swan!
Wilson…. you’ve got a Beautiful Swan.
(I’m convinced the reason Cessna gave the 172 squared-off tail-feathers was due to that horrible look round tails have when sitting on tricycles.)
Edit: The only round-tails … (I can think of off-hand) …that look good on tricycle gear …are Lockheed P-38’s
- AWilson
- AWilson
Re: Tricycle C170
Thanks for the nice comment!GAHorn wrote: ↑Mon Jul 28, 2025 4:01 am There was a childhood fairy-tale about an Ugly-Duckling….. which grew up into a Beautiful Swan!
Edit: The only round-tails … (I can think of off-hand) …that look good on tricycle gear …are Lockheed P-38’s![]()
In addition to the tri gear setup my aircraft had a Geisse crosswind gear installed 3 months before! I don't have any pictures of that though. I guess they didn't like it and went with the Tricycle gear. It was a tri gear almost 30 years.
