Cowling Fasteners
Cowling Fasteners
I fly a pretty nice 55 "B" model. Anytime I consider removing the cowling, I first consider that there are forty sheet metal screws in the top and another ten screws holding the bottom . Most are the same size except for a half dozen or so that are oversized. I was wondering if anyone has changed over to "Camloc', Dzus or Southco"' , style fasteners. The old sheet metal screws have been doing a great job for fifty years, but I'd like to install something more up-to-date. Appreciate any advise, what a better option would be to the screws I'm using now. Thanks,
- Indopilot
Cowling Fasteners
Thanks Brian, Do you find the cowling removal a lot quicker and easier compared to sheet metal screws ? I would think a 337 should work for the mod.Indopilot wrote:I just bought a cowl that has been changed over to cam loc's. I think it came with a 337 for the mod. I can double check. Might be a basis of approval for a Field approval if you are interested. Brian
- Indopilot
As far as quicker and easier, on 172's with cam locks the answer is yes to both. This cowlinfg is also modified for a 180 Lycoming installation which is why I came into possesion of it. We are not yet ready to install our 180 so it is spare for the moment.
The 337 is a Field Approval out of Sacramento California, dated 1993. the work Accomplished reads as follows;
Remove cowling from A/C & all tinnerman nuts.
Fit Camlock2600receptacle & camlock 2600 studs. Rivet receptacle to
cowling and firewall. Install studs & retain with camlock retaining rings.
Reinstall cowling.
Not exactly rocket science but it worked for him
. If you send me a fax number I can fax you a copy if you'd like. Brian
Reinstall cowling.
52 170B s/n 20446
56 172 s/n 28162
Echo Weed eater, Jezebeel
56 172 s/n 28162
Cowling Fasteners
Indopilot wrote:As far as quicker and easier, on 172's with cam locks the answer is yes to both. This cowlinfg is also modified for a 180 Lycoming installation which is why I came into possesion of it. We are not yet ready to install our 180 so it is spare for the moment.
Reinstall cowling.
Not exactly rocket science but it worked for him. If you send me a fax number I can fax you a copy if you'd like. Brian
