CAVU Mark wrote:Well Abe has perfectly described what is going on with my 170A, original generator and probably a replaced regulator. Generator was rebuilt last May, regulator history is unknown. Today I checked and cleaned the VR grounds, ohm meter says 0.3 ohms or so. Tried cleaning the points and saw the twitch diminish, swing wide and wildly, stop charging altogether and then back to the twitch. Reposistioned the plane and the twitch was lessened.
All this happens without a load on the plane, and occurs even more so with a load. Twitch can be from a few 3-4 amps to almost stop to stop on a 30Amp meter, center zero. Sounds like I need to chase some ground issues in the entire airframe.
Any troubleshooting tips or should I just increase my insurance?
Mark
Mark,
First, use a small jumper-wire and connect your generator small terminal (Field) directly to Ground...and see if you have a steady charge. If so...the fault lies either with your regulator (...or your gen-fld-terminal-to-regulator connection thru your master switch.)
If connecting your gen fld terminal to ground does not provide a charge, the fault is likely within your generator or your generator has lost it's polarity.
To re-establish generator and regulator polarity: With engine NOT running but with Master Sw ON... MOMENTARILY jump your regulator ARMature terminal to it's BATtery terminal. (This causes a short spark...and establishes a residual-magnetism within the generator and regulator). Now with no jumpers at all, start your engine and run it up to 1500 rpm or higher and see if your gen/reg now produce a charge. If YES...then it was lost polarity.
If no...then try the gen Field Terminal to ground again and get back to us.
REmember: Your cockpit master switch provides TWO circuits. One: it actuates the battery-solenoid by giving it's small terminal a Ground. Two: It connects the gen Field terminal to the regulator Field Terminal. (The regulator controls the generator by controlling the generator's field-terminal connections to ground. This is why the regulator MUST have it's base connected to GROUND.)
