High Fuel Pressure on '48 170
Fearless Tower
Post by Fearless Tower »
Finally did the functional check flight on 96V yesterday - )Overall, it wasn't too bad - just a couple of squawks here and there. One thing we noticed was that the fuel pressure runs fairly high at high power settings (around 4-5 PSI). Red lines per the AFM are min 1 and 6 max. Green on the gauge is 1.5-3 PSI.
I suspect that this is due to the brand new fuel pump that we installed (turned out the existing one was merely a deocration - the internals were so worn out and shot that it wasn't doing anything).
Is there a way to adjust this, or is this a common thing in '48s?
Andrew Hochhaus
N3996V - 1948 170
n3833v
Re: High Fuel Pressure on '48 170
Post by n3833v »
With a new pump, mine runs between 4 - 5 lbs. I accept this as normal.
John Hess
Past President 2018-2021
President 2016-2018, TIC170A
Director 2005-2014, TIC170A
N3833V Flying for Fun
'67 XLH 900 Harley Sportster
K3KNT
Larry Holtz
Post by Larry Holtz »
Mine runs just above 4 pounds. As far as I know, it is the original.
Larry
Fearless...before you go trying to adjust that pump... check the calibration of that 60 year old gauge. :wink:
Fearless Tower
gahorn wrote:Fearless...before you go trying to adjust that pump... check the calibration of that 60 year old gauge. :wink:
Agreed!
Andrew Hochhaus
N3996V - 1948 170
