![Shocked 8O](./images/smilies/icon_eek.gif)
Headliner Wire supports
I'm looking to install a new headliner in my 1948 C-170. The headliner that is in it now was made up by the previous owner and obviously not original. The problem is the support wires, Cessna part number 0511011-3, -20, -9 and -21 are not there!!
Does anyone know whether these wires are available or could be re-manufactured using some other material. thanks
Re: Headliner Wire supports
ordinary, steel, (gas) welding rod should work fine.
I was thinking the same...... Plenty of that stuff around, thanksgahorn wrote:ordinary, steel, (gas) welding rod should work fine.
![Very Happy :D](./images/smilies/icon_biggrin.gif)
If you use stainless steel welding rod...it won't ever rust and stain your headliner.
Another solution is to use fiberglass fly-rod material cut to length.
Welding rod is too short. Go to a steel supply outfit and buy two ten foot lengths of eighth inch stainless rod. You will use it all. Works perfect.
Scott.....use to be 53B
OK thanks. I was looking at it last night and I will need it all for sure. The past-past owner removed everything!!cmsusllc wrote:Welding rod is too short. Go to a steel supply outfit and buy two ten foot lengths of eighth inch stainless rod. You will use it all. Works perfect.
![Evil or Very Mad :evil:](./images/smilies/icon_evil.gif)
I managed to find some from a 52 model. The 48 is slightly different, anyway welding rod works but you have to make sure you get the correct radius bend. I would go on Barnstormer or whatever and see if you can find some factory parts.
I happen to have my headliner bows out and in my basement for my A model which should be the same as a '48. If it helps I can trace the curve and measure the length.
The OEM front wire is a 2 piece, it must be fabricated as a 1 piece if the speaker is removed.Bruce Fenstermacher wrote:I happen to have my headliner bows out and in my basement for my A model which should be the same as a '48. If it helps I can trace the curve and measure the length.
That was the case for me as my speaker was removed.T. C. Downey wrote:The OEM front wire is a 2 piece, it must be fabricated as a 1 piece if the speaker is removed.Bruce Fenstermacher wrote:I happen to have my headliner bows out and in my basement for my A model which should be the same as a '48. If it helps I can trace the curve and measure the length.
Piano hinge wire works great and has some temper to it as well as corrosion resistance.
Happy New Year to all.... Hopefully this bird will fly this year... Anyway, in the 170A IPC, figure 40, item 23 , is a bow which is 2 piece, and sets one end in the tunnel, and the other end is shown just above the rear window. All the other bows have a slot\point\hook for setting into, but on this #23 I have no place for it to set above the window. Is there supposed to be a point in the upper window frame? or is it free floating? The headliner that came with the project was a B model and not installed.. any ideas?
Rick
Rick
Rick Champagne
C-170A N5475C
C-170A N5475C
I can't get to my A model till next week to look but I don't recall any floating rods. Fig 18 shows a headliner bow in that location but it is pretty vague as to the exact location.
This is from a '52 B model. Fig. 22-11 in the C-170A IPC, p/n 0511133. Available from Preferred Air Parts.
