IOWA'S 170
iowa
Re: IOWA'S 170
Post by iowa »
also, i believe the notch at the top of my shock panel
was, indeed, there originally!
as shown in this diagram
i think the original compass used this notch to hold
the shock panel in place
what are the odds of finding this original magnetic compass?
dave
1951 170A 1468D SN 20051
AME #17747
iowa
Re: IOWA'S 170
Post by iowa »
AME #17747
Re: IOWA'S 170
Very nice!
iowa
Re: IOWA'S 170
Post by iowa »
repainted panel again
plan to paint the bezels matador red
if I come up with the right color
dave
'iowa'
AME #17747
Re: IOWA'S 170
I like your result so far Dave. Nice work.
Re: IOWA'S 170
As you still have the center bar, as it looks you found out, it's fairly easy to fab a mount to attache to a longer screw placed through the center bar. This is seen quite often with those who still have the "split" windshield. You would be amazed at the view without that bar or more accurately, how much that bar blocks or interferes with your view.
iowa
Re: IOWA'S 170
Post by iowa »
since my L-4B has 'two' windshield bars,
only one on the 170 doesn't seem bad at all.
i've never ridden in a single piece WS 170
just for info tho,
is it ok to put a one piece into the older 170's?
dave
AME #17747
Re: IOWA'S 170
Dave, all the 170 windshields are actually one piece. The strip in the middle is there to hold the top of the windshield into the fuselage. All 170s without the strip must have another method to hold the windshield and that is done several ways under different STCs. So yes, all models of 170 can have a "one piece" windshield.
johneeb
Re: IOWA'S 170
Post by johneeb »
Dave, that is a great looking L-48! What is the difference between an L-4 and L-48?
Re: IOWA'S 170
Bruce Fenstermacher wrote:Dave, all the 170 windshields are actually one piece. The strip in the middle is there to hold the top of the windshield into the fuselage. All 170s without the strip must have another method to hold the windshield and that is done several ways under different STCs. So yes, all models of 170 can have a "one piece" windshield.
I put a thicker windshield without the center strip (Great Lakes brand) in my 170B in 2010. I wish I had done it decades ago; it’s amazing how much visibility you give up with that 1-inch strip in the way.
iowa
Re: IOWA'S 170
Post by iowa »
i'll check out the 170 windshields at Oshkosh
My L4 is an L-4B
not L-48
L was for liaison
4 meant it was a piper
B was the type of piper L4
i'm very excited that is will be cooler at Oshkosh
we've been running 95+ here in Iowa
cold front moves through today tho
dave
'iowa'
AME #17747
Re: IOWA'S 170
While off subject, like many airplanes, Army Air Corps L-4s had many models which indicated models or improvements, indicated by a letter after the designation. The last I believe was the model H. Dave has a very nice L-4B which he restored, several years ago, that he documented at the Cub forums. You will notice his is not green. This is because his early example of an L-4 was part of a small number of aircraft used for training at Ft. Sill if I recall correctly.
iowa
Re: IOWA'S 170
Post by iowa »
yes, it was # 82 of 100 L-4B's
that went to Fort Sill
with final coat of O.D. left off
i flew to the their 100th anniversary
at Henry Post field on Sept 1 of 2018
if your interested
you can read all 148 pages
of my restoration here
https://www.j3-cub.com/threads/iowas-l4.15718/
dave
AME #17747
Re: IOWA'S 170
iowa wrote:also, i believe the notch at the top of my shock panel
dave
Dave,
I saw two 170's at Oshkosh with this same notch cutout. Here's a picture of how the magnetic compass mounts to the panel:
It rivets onto the main stationary panel bulkhead so the original compass did not "use this notch to hold the shock panel in place." You're right though in thinking this has something to do with the compass mounting on top of the panel as the hole is not shown on the standard panel in figure 40. The notch is there to allow light from the top center bulb on the gyro panel to light up the compass too. Take a look at the highlighted circles below:
Finally, notice item 43 on fig. 76. Cessna calls it a "light conductor". Notice the half-round notch on the bottom of it. My guess is that it slides down through the slot in the main panel cover to sit just above the light bulb there. It was missing on my compass housing. Anyone have one I could duplicate?
iowa
Re: IOWA'S 170
Post by iowa »
made it to Oshkosh!!
[still can't call it airventure]
met a lot of 170 owners and took a lot of panel pictures
posts of them coming up
dave
'iowa'
AME #17747
