Looking at a picture of an exhaust system does not substitute for a close personal inspection. But from what I can see of the system Mike showed, there are no repairs to make. It looks to be in fine condition. Actually it looks to be in great condition. The system is made up of pipes that are slipped into a can. They are held in the can by rivets. The slip joints are not tightly sealed. They never were.voorheesh wrote:If we could go back to the exhaust leak for a minute, Looking at you pictures, I would advise you get that system properly repaired or replaced. I would not use NAPA tape on an aircraft exhaust system. ....
The suggestion that muffler repair tape be used to repair a cracked or broken exhaust is not mine nor has it been the recommendation of anyone here ever that I'm aware. However we recognize that these exhaust systems of either make, leak. And they leak when new. The leaks are at the joints. Some systems leak worse than others. Sometimes there may be better ways to address bad leaks. A different clamp style for example on the Hanlon Wilson system sometimes offers improvement. And some people have been able to improve the seal at joints, at least for some period of time, with the muffler tape.
I understand that we are not the originators of the idea of using muffler tape at the joints. I believe that suggestion came from a very well respected engine overhaul facility.
Let me also add that welding the joints closed is not the answer. I have a pancake muffler system that a professional exhaust "aero fabricator" welded the slip joint. It probably worked well right up until the gapping 2" rip in the can was formed. Shame because other than the rip the system looks like new.
