Rebuilding airframe, what to do with corrosion.
Perhaps this discussion was hammered to death before I joined the group, but to me is a very important issue. As always, I try to gather knowledge and experience to work with my own before making a final decision on what to do. Currently I am doing a correct chromating of the interior with intentions of pumping the seams with something after the exterior paint is done. Any comments on time proven preventatives?
A while back someone referred to the "tar" soundproofing sprayed in 170 fuselages. Does anyone know what this "tar" stuff is? What's the best way to clean it off? I'm doing a total rebuild of a 1953 170B and the fuselage was full of it. No mention in the logs of anyone ever spraying it in.[/list][/quote]
For what it's worth, paint stripper lifts it too. If you're in there
stripping other stuff, might as well slap some on the tar
junk.
We used paint stripper and scrubbed with a scotchbright pad, then
switched to lacquer thinner / scotchbright for clean-up.
That tar crap *is* nasty stuff.....
Bela P. Havasreti
'54 C-170B N170BP
junk.
Bela P. Havasreti
'54 C-170B N170BP
Paint stripper works very well. I put a 4" hose to my dust collecter in the strobe hole and the inspection port in the tail ( depending on where I was) to bring in fresh air. Solvents inside the fuselage can kill you. After you have pulled off most of the stuff, wet your rag with prep sol or mineral spirits. It congeals the material and makes it very easy to clean off the last bits. Diamond Grip rubber gloves (disposable) are the best ones available. Keep an eye on the fingertips, as you may not know for a while that they have disetigrated. I am looking into a product by Fluid Film that is lanolin based to pump the seams with. Fluid Film sells their type A to the coast Guard for their helicopters. Lanolin products have amazing corrosion resistant qualites.
