Gordon,
I looked at the site in your post and it appears that the valve rotaters are used only on the Lycoming cylinders. The link specific to O-300 leads to larger engines with no information about O-300's.
I did find a link ( http://www.eci2fly.com/Tech_Ref/titan/Ballizing.htm ) explaining Ball sizing.
Johneb
millennium cylinders
Although that partilular site/link it to ECI's system, ....rotators are indeed common on larger Continentals as a genuine TCM item.
Joe wrote:
The cylinders were $745 each, outright and complete from Premium Aircraft Parts. At the time (October) they were offering to ship them free via UPS ground. But UPS doesn't drive up to Alaska, so I had them sent Priority USPS which cost about $70.
Johneeb wrote:
Johneeb,
The ECI site has a lot of information, but it is not always easy to find. At the link below they discuss their approach to reengineering the 0200/0300 cylinder.
http://www.eci2fly.com/Tech_Ref/titan/200-300-C.htm
From that page:
When I was researching the ECI Titan cylinders I downloaded a pdf file with good technical information about the rotators in their new 0200/0300 cylinders. It should be found at:
http://www.eci2fly.com/Tech_Ref/si/sitoc.htm
Click on Service Instruction 02-8 "0-200 Valve Train Upgrade."
I also have a picture of one of the cylinders installed on my plane, showing the rotator on the exhaust valve. There isn't a lot to see, but you can tell it looks like the rotator in the picture at the link I originally posted. And the valve spring cover is noticeably different from the intake side.
Can you just drag and drop pictures to these posts?
Gordon Sandy
1948 Ragwing
Joe,[W]ere those bad boys pretty expensive?
Johneeb,
From that page:
Engine Components, Inc. (ECi) improves the original C-75,85,90,125,145/O-200,300/GO-300 series cylinder design with innovative features and benefits to the TITANâ„¢ Cylinder Assembly product line. Customary conventional characteristics will stand up to time, but based on the success of the TITAN 470/520/550 series cylinders, many of these features were incorporated into the re-engineering of the new C-75,85,90,125,145/ O-200,300/GO-300 series cylinder.
Valve sticking has been a chronic problem for these cylinders in past designs, and ECi now provides solutions for the problems that face our aging aircraft fleet. “We have added a rotator to the exhaust valve to allow free motion and rotation of the valve each time it is opened. Rotation reduces the build-up of carbon and varnish by always presenting fresh mating surfaces to the stem and guide,†explains Gary Garvens, CEO, ECi. “Fresh, clean faces promote heat transfer to the cooling fins and reduce the likelihood of guide wear.â€
Gordon Sandy
1948 Ragwing
