Haven't made a final decision what to do with my mag situation. But I'm learning a lot about mags. One thing I know is no mag if it's not turning will produce a spark.
Mine froze. Had I been in the air the frozen mag gear might have taken out the common cam gear stopping the other mag or the cam or both. it wouldn't have been a pretty picture.
I'm surprise now that I'm thinking about it that the mags don't have some coupling designed to break like a vacuun pump when a jam occures. Maybe they do I'm just missing it in the design and mine didn't appear to work.
As it is when the bearing failed parts of it jammed the rotating magnet and probably due to the slow rotation of the idling engine and quick response to shut of the engine just bent the mag shaft and gear out of the way of the cam gear.
Most of the Bendix parts are reasonably priced. The two exceptions are the the parts I need the rotating magnets/drive shaft and the mag gear. The magnets list at over $800 and I've found one new for $459. the mag gear is $479 from Spruce.
I've got a spare mag gear but the rotating magnet is another story. Seems an 1994 AD made most of them produced earlier than that unairworthy. I have 5 examples of these magnets that I can't use.
I have a friend who claims to have a good rotating magnet but if that doesn't turn up I'll probably be going with new Slicks which will cost $1200
Besides the compelling story George just told about Bendix mags,
can anyone think of a reason to keep them?
One other thing. I think I'll be servicing the bearings and other mysterious parts inside my mags about every 250 hours regardless of how well their working from now on.
