Winterization Kit -Question
webmaster
Site Admin
Post by webmaster »
Thanks Miles and Bruce!
I'll probably try to fabricate some covers similar to the picture, but I sure don't like the idea of blocking any of the cabin or carb heat inlets. If its cold enough to need less cooling air for the engine, then I need more heated air for the cabin!
Dale
jrenwick
Post by jrenwick »
There's a very good thread on this here: http://cessna170.org/phpBB2/viewtopic.php?t=3110
Robert Eilers
Post by Robert Eilers »
I followed the suggestion regarding the use of Duct tape to improve the engine oil temps. Worked great - oil temp got up to 180 and stayed there for the entire flight - OAT was 40-45. Great forum - thanks.
markeg1964
Post by markeg1964 »
My father made the following cover which can be installed or removed by loosening the two screws and sliding the cover to the side. It looks like a factory part although it only helps a little.
Back side of cover:
Mark
Another cover I've seen used oil sump cooling air hole in the nose bowl is a metal inspection hole cover with a holding spring on the back, such as is used on the under side of fabric covered wings.
