rudder bellcrank
Re: rudder bellcrank
A number of years ago I was flying a stock 170A out of 100 Mile House in British Columbia, a one way strip, down hill with a good tail wind. I was just ready to lift off when the tail wheel slammed back to the ground and I was headed off the left side of the runway. I rolled in enough aileron that the right wing tip should have been ground down but I got it under control again with all wheels on the pavement but not enough room to stop before the fence. I was able to nurse it off enough to clear the fence the level off and fly down the valley to build up more speed then fly on to my destination. After parking the plane
( and cleaning out the seat ) I did a walk around just to check it out. No scratches on the wing tip but the rudder bell crank had substantial damage from hitting the stop. So it can be done under normal (??) usage.
Scott.....53B
Scott.....53B
He's correct, of course, with regard to the use of rudder gust locks...always a good idea, IMO.cessna170bdriver wrote:... my AI thought it wouldn't be good idea to add holes to the new part. He was of the opinion that the bumpers wouldn't be necessary in normal use as long as some sort of rudder lock is used when the airplane is stored outside. ...]gahorn wrote:Miles, the bumper PN 0660341 is an L-19 part and available from Air Repair, Inc, Cleveland MS. 662-846-0228
If your bellcrank has only lost it's flange and the web not extensively damaged you may be able to install the bumper and not have to replace the entire bellcrank. It can be done "in situ".
The only stops I've seen are actually AN bolts. Your left one is the only difference I've seen.
As for installation of the bumpers...Del added them to my bellcrank without any problem and I'm very pleased.
Got photos? I still have the parts, so maybe that could be an item to accomplish this year (add it to the listgahorn wrote:...As for installation of the bumpers...Del added them to my bellcrank without any problem and I'm very pleased...
The only complaint I have about Del's work is....he forgot to spray it with ScotchGuard to keep the dirt and oil off!cessna170bdriver wrote:Got photos? I still have the parts, so maybe that could be an item to accomplish this year (add it to the listgahorn wrote:...As for installation of the bumpers...Del added them to my bellcrank without any problem and I'm very pleased...).
- Dallas170
gahorn wrote:The only complaint I have about Del's work is....he forgot to spray it with ScotchGuard to keep the dirt and oil off!cessna170bdriver wrote:Got photos? I still have the parts, so maybe that could be an item to accomplish this year (add it to the listgahorn wrote:...As for installation of the bumpers...Del added them to my bellcrank without any problem and I'm very pleased...).
Reviving an old thread....
Was it necessary to modify either part? I got the L-19 bumpers, but my A&P says the holes do not line up with the holes in the bellcrank in any orientation.
The reason to add the "bumper" was because the head of the bolt which limited rudder travel was damaging the bellcrank. This is also the reason the L19 has that device. It's an easy thing to add, and it's not required that the existing holes line-up... simply drill new ones to mount the "bumper" and ignore the existing ones, if you wish to do this.Dallas170 wrote:[...
The beauty of rivets is they do not need an exactly "sized" or reamed hole...they fill the void to make a secure attachment.
- Dallas170
That is the same issue I was having and found this thread. Is always nice to discover you're not the first to have a certain problem and someone has already solved it! From your pictures, I thought the holes would line up, so I thought I might have gotten a different part.gahorn wrote:The reason to add the "bumper" was because the head of the bolt which limited rudder travel was damaging the bellcrank. This is also the reason the L19 has that device. It's an easy thing to add, and it's not required that the existing holes line-up... simply drill new ones to mount the "bumper" and ignore the existing ones, if you wish to do this.Dallas170 wrote:[...
- 170C
Rereading George's earlier (2011) post about Del forgetting to Scotch Guard the Scott steering area, surely there wouldn't be any oil ever get back there from a Continental
I think Continental dedicated themselves to continuing the aeronautical tradition of designing their engines to mimic radials!170C wrote:Rereading George's earlier (2011) post about Del forgetting to Scotch Guard the Scott steering area, surely there wouldn't be any oil ever get back there from a Continental![]()
- mit
- LRPartridge
26 July 2021
Thank you gents for the rudder bellcrank discussion. Very useful. It is one of my many "little projects" with the 1948 flying machine.
All the best, Leslie
Leslie Partridge
- n2582d
McMaster-Carr p/n 1688K5 Ultra-Low-Friction Oil-Embedded Sleeve Bearing.GAHorn wrote:... Item 26 is an "Oilite" (brand/type) bearing, A-325-1 and Item 27 is a bushing, PN 0431119 , and you need both of them to adapt the rudder bellcrank to the rudder hinge.
By the way... "Oilite" is a brand-name of a mfr'r who makes bronze plain bearings. Plain bronze bearings are porous and are usually soaked in oil for 24 hours prior to installation. They retain the oil for long periods and only need occasional lubrication, per the maintenance manual. Ordinary SAE 30 wt motor oil is fine. McMaster-Carr can supply these under the SAE 841 specification:
http://www.mcmaster.com/ Go to their "bearings" pages, and look under bronze sleeve bearings, and you'll find the exact measurements you require, and the prices (typically about $5 each.)
Hope this helps.
- Desertflyer
Both the bearing and the bushing can be obtained from McFarlane www.mcfarlaneaviation.com/. I saw earlier that the A-325-1 bearing has been superseded with PN S1003-11A and the PN 0431119 bushing number appears still good, though McFarlane's number is 0431119K. Both are described as used in the Cessna 120 and 140.
