Oil Pressure ?
jatkins
Re: Oil Pressure ?
Post by jatkins »
Thanks Bruce,
As mentioned above, I will get a calibrated gauge on the engine, and make some
adjustments as required after.
I was not certian if I was chaseing my shadow at first , being concerned about high oil pressure.
CF-HER
52 170B 20292
Re: Oil Pressure ?
N9149A wrote:..George is not correct if he is saying washers under the spring will not adjust the maximum oil pressure higher or removing them will not lower it. They do have a good effect at this. He is correct as I've already described washers or any method of adjustment will have no effect on any pressure less than the maximum....
Sorry if I used fuzzy language... I was not saying washers would not affect relief pressures. I was trying to point out that it will not correct other causes of low pressure. IN other words, do not think of this device as an oil pressure regulator. Think of it as a "safety valve" against excessive pressure when your oil is cold. That's all it's intended for.
