Poll: Carb Air Box Upgrade Possibility
- blueldr
Re: Poll: Carb Air Box Upgrade Possibility
Joe Rogg down in Arizona specializes in carburetor air box repairs and rebuilds. Try Google to find him.
Hello, new guy here. Owned C140 for 26 years. Now a (cough) a Mooney 64C model but after 14 years with it thinking of going to a 170. Easier to work on. I'm getting to old to crawl under the wing for gear inspections and to tie it down
Anyway to the point of this missive:
When I had my 140, my airbox went south in the bushings also so I devised a fix.
Removed the bushings and laid a 1" dia neoprene grommet against the side of the airbox with a 1/4 dia hole for the shaft (nice press fit, airtight) and then made a 4 legged steel bracket (legs bent down to surface of airbox sides with a hole in the center for the grommet grove to fit tightly in.
Welded the 4 legs on each bracket (1 each side). Painted same.
Put in grommets and now had a "never wear out" bushing for my airbox.
Did a 337 (this was 40 years ago) and went to my local "GADO" and they looked at it and the only question they had was " It's rubber, what about a fire"? I said, "We have grommets in the firewall on the airplane don't we"?
It was then signed off legal like.
Just thought I'd throw this in the mix.
This POLL thread was not successful for it's intended purpose and is locked.
