N7A had all those marks. I baffle them with the detail then they can't see the big stuff.gahorn wrote:Did Rick bust you for no 5 psi redline on your oil press? (Or is it just not evident.) He got me.
That's an interesting idea ... if you had the SVS installed you could use it to spin up your gyros on the ground before takeoff.cessna170bdriver wrote:Precise Flight SVS III Standby Vacuum System
That's the primary reason I installed it. I usually pull it on right after engine start, and push it off right before takeoff. Of course, the vacuum goes away with wide open throttle, but then the venturis take over. It also works well at the reduced manifold pressure generally used during an approach. There is an AD on the system, to test the shuttle valve periodically to make sure it's working, but it's not difficult or expensive to comply.DaveF wrote:That's an interesting idea ... if you had the SVS installed you could use it to spin up your gyros on the ground before takeoff.cessna170bdriver wrote:Precise Flight SVS III Standby Vacuum System
The light IS just a low vacuum indicator, but it is only on the primary source (venturis, in my case) side of the SVS shuttle valve (automatically switches to the strongest source). I think the original intent of the system was to provide a vacuum source in the event of vacuum pump failure. Since my vacuum pump (venturi system) is "failed" on the ground and when slow on an approach, that's when I use it.DaveF wrote:Oh, I misunderstood your description of the light. I thought it was just a low-vacuum indicator. And here I thought I had an original idea.
At one time I was thinking about adding this to my 170, for exactly this reason. I called the manufacturer and spoke with someone in engineering about what I wanted to do, and why. He said yes, it works well for that purpose, and it's something they can recommend. FWIW....DaveF wrote:That's an interesting idea ... if you had the SVS installed you could use it to spin up your gyros on the ground before takeoff.cessna170bdriver wrote:Precise Flight SVS III Standby Vacuum System
It was a "jab" Bruce created specially for me.blueldr wrote:What in hell is this one? A "Mary Kay" Special?
Unfortunately, the hole saw got away from me on one of the holes (bottom row, just right of co-pilot's yoke)Aryana wrote:Nice matte finish. Did you end up anodizing it?
