My '55 170B Project
- JohnNielsen
Re: My '55 170B Project
Over the top of the panel, there is a 'U' shaped overhang piece that has a strip of green LED strip lites on a dimmer. This will go on after the we are done removing the panel so often to work on things behind it. I love flying in the night and end up turning the panel lites down to about nothing to take advantage of seeing the wonderful scenes presented in night flight.
- JohnNielsen
It has been a while since I updated you with the project and a lot has been accomplished. Top Flight Avionics completed and tested all the avionics and inside wiring. I got the firewall insulated and now made the move to get the plane back to my own hanger. This week we made and secured connections between the cabin and engine for carb, prop, heat and air controls. We installed an plumbed all fluid lines for primers, oil and fuel pressure. The battery box was installed, new relays installed, new wires, and switches and tested same...It is a cool feeling to hit the master switch and hear a click and see power to the bus. EGT & CHT wires are now routed and connected. Remote senders for Oil and fuel pressure are mounted and wired to the EFIS. Aeroquip lines have been measured and are being made for all fuel supply from gascolator to carb. It took one whole day to return the trim tab actuator and chain back to the proper position....I am in need of one actuator clamp if anyone has one...
We pick up the doors tomorrow from the paint shop and begin installing new windows and seals, then installing the latches. Seats have been done for a long time now. BAS Inertial belts will be installed.
Meanwhile, at the other shop, the wings are now completed. The tanks are installed, along with tips, lights, strobes, covers and heated pitot. As soon as the mud dries up we will trailer them back to meet the plane...perhaps mid-May.
Going to re-skin the flaps because of a few small cracks, then clean and paint them along with the ailerons. All new wing and control parts are on hand from McFarland, ready to be put to good use. Should be ready to fly by end of May???
- johneeb
John, even without the rest of the instruments installed that is a really clean neatly laid out panel.
- JohnNielsen
Now with the plane back at my home airport hanger only 3 miles from home/office; I have been able to spend a considerable amount of time on my project. This weekend, we got the wings installed. Since the last post the following have been completed:
All wiring, fluid, instrument, control connections between cabin and firewall are done. All wires, bundled and secured. So now we are DONE with firewall forward!!
The baggage door was painted and installed with weatherstrip and adjusted.
The main door hinges had quick release pins installed, new door seals and got their color paint. They are now ready for the windows that are a side bench project.
Cowling has been painted with the colors and test fit.
Cabin wiring checked, tested and secured.
Interior insulation continues with use of 1/4" foam on all interior surfaces.
Trim tab installed and cabled tensioned.
Rudder stops and travel adjusted.
Right wing aileron and flap cables attached to bellcranks. (waiting for flaps and ailerons to come back from paint shop next week.)
Panel installed and tested as much as possible w/o engine running.
Interior tailcone vacuumed and installed Selkirk extended baggage tray and bulkhead panel.
Working on cabin vents on wing roots.
The left wing is next to make connections and install cables and bellcranks. Making some adjustments and new trim covers for around wing roots.
I think it will be flying in June!! And plan to bring it to OSH to park with the Club.
John Nielsen
N170KW
John Nielsen
N170KW
- Kyle Wolfe
Hey Bloomer John - looking really good!
Glad to hear you'll be in OSH (with your guitar I expect!)
Kyle
54 B N1932C
57 BMW Isetta
54 B N1932C
57 BMW Isetta
- JohnNielsen
The main reason I sold the RV6 and went back to a C170 was that I could not fit a guitar in the RV6!! With this set up, I can fit not only the guitar, but the full PA and members of my band!!
- JohnNielsen
The last few weeks have been consumed with making the fits of trim and wing parts...it takes a lot more time than expected!!
So now the control cables for flaps and ailerons is complete. The flaps and ailerons are going to be delivered this week for installation. Got the new window plastic installed and are waiting for hinge material to install the windows to the doors.
The cowl is fitted and ready for final install. We will run some fuel through the system from each tank and out the (un-hooked) supply hose at the carb to verify proper flow and free of debris. While waiting for wing parts, I continued on the flooring. Before doing the front area, I paused to install the plumbing for the hydraulic skis. We had to completely redesign the placement and mounting of the pump and oil tank, but it fits nice now. Might be able to fly it in about a week or two!!!
Isn't blue faster than red or green?
Blue and yellow make green. (only prettier)
- JohnNielsen
OK, I need to update this post. The plane is flying again!!!! Last time in the air was 1977. Took about 1.5 hrs to get the new engine to seat the rings. I love the quiet smoothness of the MT 3-blade prop....fun to run at 2000 rpm and higher power settings.. Fuel flow at full power gets your attention at 18 to 19 GPH, but in cruise it goes down to 8.7 to 9.2 GPH when leaned. She climbs in excess of 1000FPM at full gross in 85 degree days and get off the ground in about 3 -4 plane lengths. Lot's of paperwork...15 total 337 reports filed that are 2.5" thick total with all the attachments!! I spent much more than planned, but I have a 'new' plane that can carry 4 and gross amounts of cargo in comfort and style for less than half the price of a new 172 or 2-place Husky.
Still need to finish the interior fwd panels that will carry the heat duct pointing to the rear. Also need to finish placement of the Hyd Ski pump for winter use. I got a chance to fly it to OSH for 2 days and camp with the 170 group...THANK YOU DAN!!
Now I plan to take her sightseeing about the USA. Hope to run into members along the way.
- 170C
Really looks good John. Now you can enjoy the fruits of your labor (and $$). What is your useful load now?
- JohnNielsen
I found the prior latest W&B and compared it to the new EW of this one of 1406 lbs. I only gained 76 pounds. 2200 lbs is the MGTOW of the 170B.
John,
Nice work! Would you post some performance info?
Can you tell me where you found your fenders/mud flaps? I have a '59 150 Taildragger project that I would love to put them on.
James
5729E '59 150TD "BarFly"
- JohnNielsen
For the fenders, I got the FAA list of Cessna 188 Agplane registrations and began calling those owned by commercial spray operations. Found a shop who had a set and some spare parts in a box. They require a bit of mod to fit the 170 gear, but quite easy. John
