Continental made a few sumps from aluminum, it is not a change from type design.voorheesh wrote:To answer your question: Appendix A to Part 43 Major Alterations (v) installation of structural parts other than the type of parts approved for the installation. The sump of an 0-300 is a magnesium structure that collects the oil that lubricates the engine. To change it to aluminum is a major alteration that will require an engineering evaluation. This "opinion" is not based on some bureaucratic concern over the definition of the word "structure". It is based on the simple fact that you wouldn't want to modify something as important as a sump without making sure you are covering ALL THE BASES and producing a component that will be safe and reliable.
Wy wouldn't a exact duplicate of the sump made from aluminum be safe and reliable?
