Refinishing Spring Gear legs
Re: Refinishing Spring Gear legs
I would drop off my gear there, but then the inner Scotsman might cost me some sleep! Whats the rate for a pair of legs?
Not much sense now, they just had a major chemical fire last week. the whole place is ashes. and a huge EPA night mare.hilltop170 wrote: Tom-
Would you please post the contact info for ASCO? I have never heard of them.
Thanks!
Here is they were;
http://www.askogroup.com
Here is the story:
http://www.seattlepi.com/local/slidesho ... -94703.php
Last edited by T. C. Downey on Fri Oct 10, 2014 12:42 am, edited 2 times in total.
When you have a .010" to 020" dents in the surface of steel, you can certainly see the results with out a magnifying glass. The whole surface looks different than wrought steel that just came from the rollers.c170b53 wrote:Well you can see it with a 10X and its actually a requirement after peening to ensure the treated area (although it should be) is uniform (no missed spots).
As for hydrogen embrittlement, well caustic substances can cause this issue in high strength steel, doesn't mean it will but it increases the probability.
If you use power tools you might want to think about heat generation with respect to any metal your working on. I know we had to remove Cratex wheels from our workplace because knowledgeable personnel knew they where generating heat but did not realize the amount of heat which unfortunately was damaging metal. To be fair, initially they used cratex sticks to remove defects (ie gouge in a skin) and would work the repair by hand. Cratex wheels driven by air tools air came along and increased production but introduced the heat generation problem.
I think the DIY could get by with portable media blaster and rattle cans and although possibly its not ideal not to do a full lookie- see, its better than wondering. Bruce how am I doing in dissuading you from putting this off, further?
hydrogen embrittlement is relieved by a 24 hour bake at 400 degrees, that is all it requires. The problem becomes finding an oven large enough.
Tom, I don't think we have been working on the same type of products.
I can't seem to agree with Tom Downeys comment about bead blasting peening over cracks. Glass beads peening hard steel gear legs ??? I can't see it at all.
Here is they were;
Here is the story:
http://www.seattlepi.com/local/slidesho ... -94703.php[/quote]
I use Asko for a lot of different things. Plating and and chromic acid dip for magnesium parts of the Nene 10 engines we work on for the T-33's. Canadian (CT-133's) I was talking to Tom Anderson of The Landing Gear Works last week and asked if the fire had affected him, he had several sets of gear up at Asko for re-work and he said that after the fire he got them back quicker than usual. Their entire plant did not burn down they have two buildings the one to the east is the one that burned. All of the work I have had done was performed in the west building. They may still be in operation.
Here is they were;
Here is the story:
Read thisblueldr wrote:I can't seem to agree with Tom Downeys comment about bead blasting peening over cracks. Glass beads peening hard steel gear legs ??? I can't see it at all.
AC 43.13-1B
TABLE 5-5. Pre-cleaning methods for penetrant inspection.
I guess that rules out using a needle gun as well. ![Wink :wink:](./images/smilies/icon_wink.gif)
