Installed 180 Landing Gear
Re: Installed 180 Landing Gear
Ryan-
Yep, early 140 or 170 symmetrical gear, can't tell which. Thanks for the picture.
If they had 3 axle holes instead of 4 they could have been heavy 195 gear which were the same vintage.
More comments on posting pictures;
-Un-check "Disable BBCode" in the options tab
-Once the picture file is uploaded to your post, a box opens allowing a caption to be added to the picture if you want one.
-Below the caption is a box that says "Place inline" which will locate the picture and caption into the post wherever you place the cursor, then click on "Place inline".
Aryana wrote:I forgot exactly which Cessna model they came from but my buddies Oshkosh Seaplane Grand Champion Spencer Aircar used Cessna gear legs on its retractable undercarriage.
They just rotate up and out of the way of the water.
Arash-
Those look like L-19 gear legs, longer than 170, 180, or 185 gear legs with skinny-er ankles.
cfzxo
Post by cfzxo »
I would agree with Richard in that the stiffer 180 gear is better for the type of flying that some of us do. the taller stance for prop clearance also helps. The taller stance look is not anything that I personally think is that important. IMO
In Richards picture from the left the first 4 gear are later 170 lady legs. I can not tell the two farthest to the right. In Ryans picture is a set of later early gear. I think they are later gear because of the 2 dimples in them. The earliest gear and 140 gear had a hole drilled through in the middle. The next gear only had a dimple where this hole once was. And then the type with two dimples. I'm sure about the first two types, the third with two dimples I believe to be correct but my memory is fuzzy on them.
"To each, one's own ca-ca smells sweet. But do not be fooled by this." - Forrest Gump
The 180/185 gear on a 170 does not look good. At all. They look WRONG!
Unless you happen to own them.
That's the truth.
An Opinion:
Early 170 gear are fine.... but they require better pilot technique for wheel-landings than the later "lady legs" which have a stiffer spring-rate.
Many pilots like the later gear because they have poor technique, and that is also why some pilots like the 180/185 gear also,.... because they have
poor technique or are incapable or unwilling to learn how to operate with them.
The 180/185 gear weighs more than original legs, but they do provide more prop-tip ground-clearance and may be useful on very rough, unimproved fields where prop-damage is to be avoided.
Otherwise, in my opinion, they are ugly hermaphrodites and odd. I would rather have an Isetta.
N2625U
Post by N2625U »
gahorn wrote:"To each, one's own ca-ca smells sweet. But do not be fooled by this." - Forrest Gump
That's the truth.
An Opinion:
In that case, don't put them on your airplane.
Oh, and Forrest Gump never said that - check your source.
It's a direct quote from a book given to me entitled, "Forrest Gump Speaks" years ago.
marathonrunner
Post by marathonrunner »
If it is written in a book it must be true
It's truly written in the book I have.
canav8
Post by canav8 »
Installed 180 gear on 13D. I tried to use the shims that I had on there but I noticed that using them didn't even come close to shimming it to the book. Anybody have any shims laying around collecting dust? Doug
52' C-170B N2713D Ser #25255
Ryan Smith
Post by Ryan Smith »
canav8 wrote:Installed 180 gear on 13D. I tried to use the shims that I had on there but I noticed that using them didn't even come close to shimming it to the book. Anybody have any shims laying around collecting dust? Doug
Are they the ones that shim at the axle?
canav8
Post by canav8 »
Sorry. Yes these are axle shims I am looking for and not the gear to fuselage shims.
Part numbers
0541111-2,
0441139-5,
and 0441139-6
Ryan Smith
I've got some. Will look at PNs when I get home.
Please be aware the gearbox to fuselage shims do have a effect on gear alignment also. If you have a excessive axle to gear leg shims then look at the gearbox to fuselage shims also. These are sometimes called wedges.not much in the manuals about this .
