New Tailwheel Leaf Springs too thick
thejetjerk
Re: New Tailwheel Leaf Springs too thick
Post by thejetjerk »
The issue still exists, the spring set I purchased from Univair last month (March 2021) would not fit. My Ap/IA spend a lot of time dealing with it. :(
Might he have tried just replacing a new main leaf with the old spring set ?
thejetjerk
Once I was aware of the issue, I gave my IA the option to use just the main leaf from the set, but he has already managed to get the new spring set to fit.
It is virtually impossible....that the entire spring-set needs replacement. The only spring which can fail to hold the tailwheel to the airpalne...is the ONLY spring that is attached to the tailwheel..... and that is the MAIN (lowest) spring.
It is more likely to cause damage to your airplane by forcing-fitting en entire spring-stack than it would to only replace the one spring which really matters in this.
dstates
Post by dstates »
GAHorn wrote:It is virtually impossible....that the entire spring-set needs replacement. The only spring which can fail to hold the tailwheel to the airpalne...is the ONLY spring that is attached to the tailwheel..... and that is the MAIN (lowest) spring.
I think all 4 of mine needed to be replaced :wink: Maybe I could have kept the smallest one.
My tail had the old bracket so I could handle the thicker springs.
mmcmillan2
Post by mmcmillan2 »
Yea, they dun wore out. Is that a tail tie down eyelet?? Where’d ya get it from?
dstates
Post by dstates »
mmcmillan2 wrote: Is that a tail tie down eyelet?? Where’d ya get it from?
Yes, good eyes. It is from Air Repair (their info below). I ended up not using it because I have a Maule tailwheel and it doesn't fit (either orientation) with the cap on the top of the tailwheel (red circled area in picture). I think it only really works with the Scott tailwheel. I think it was $20+ for the part and another $15-20 for shipping.
Air Repair, Inc 662-846-0228, L-19 PN 0642105, https://www.airrepairinc.com/cessna-l-19.html
I stand corrected. Your previous spring stack was clearly abused above/beyond the ordinary and should have been replaced even earlier.
My previous comment was made thinking of our recommendation for 500-hour preventive maintenance in ordinary use ... :wink:
dstates
Post by dstates »
Yeah, I figured I had you with that one. George... :D Replacing those springs was one of my very first repairs on my plane (shortly after replacing a couple tires and tubes).
N3454C
Post by N3454C »
I am planning to replace my tailwheel spring group I purchased from Univair in a few weeks on my '54B model. The IPC shows a couple rubber "pads" (cessna P/N 0442119-1). My concern is (assuming they are original) they should be replaced. I can not find them anywhere for sale. How have others dealt with these pads during leaf spring replacement? Any advise? Thanks.
N3454C wrote:I am planning to replace my tailwheel spring group I purchased from Univair in a few weeks on my '54B model. The IPC shows a couple rubber "pads" (cessna P/N 0442119-1). My concern is (assuming they are original) they should be replaced. I can not find them anywhere for sale. How have others dealt with these pads during leaf spring replacement? Any advise? Thanks.
Eric…don’t you have a 170-B model? …with the large, aluminum “alligator” tailwheel bracket..?? If so, your tailwheel assembly does not use those pads.
Perhaps you might wish to review the tailwheel bracket Service Kit Instructions: viewtopic.php?f=40&t=9442
N3454C
Post by N3454C »
Perfect! Yes, that looks more like it! I will review the service letter, but looks good! thanks!
redacted
Post by redacted »
Just installed a new Univair spring set. Bolted up no problem.
Nathaniel Perlman
1952 170B
N2282D S/N 20434
N3454C
Post by N3454C »
redacted wrote:Just installed a new Univair spring set. Bolted up no problem.
Sounds good! planning to do mine next weekend. I hope to have the same results~
BrianW
Post by BrianW »
I have a 55B, and purchased a new main spring U0542106 from univair. My mechanic also said it's too thick to put in with the rest of the stack. If I go ahead and buy the whole pack, will that fit correctly or fit by installing only 3 of the springs?
-Brian
