Landing Problems
As someone who paid his way through college and flight school working as a mechanic, and as a graduate of the Toyota rear-axle overhaul and repair school at their Houston technology center, and having rebuilt and repaired for the Toyota factory untold numbers of rear axles including setting the bearing preloads on those differentials and axles using dial indicators and specially calibrated torquemeters and computerized Gleeson machines.... I think I can recall the basics of bearing preloads on wheel bearings.
Can't remember that girl's name I met in Orlando tho'...
MILES!N9149A wrote:I am always amazed at the amount of collective knowledge we have here at the forum.
Need a rocket scientist, we've got one.![]()
I know just enough about rocket science to be truly dangerous.
(Ya wanna motor that develops as much thrust as a 170, but only weighs a pound or two? We got 'em.)
My sheepskin says "Electrical Engineer" but the vast majority of my career has been applied to controls and instrumentation involved in testing rockets. I agree though, "Rocket Scientist" sounds kinda cool!
![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
Hey, Dick! Ain't YOU and ME both Rock-ette Sciontists? I vaguely re-member studyin' those long-legged girls. YOu think we cud git a JOB doin' that???? ![Laughing :lol:](./images/smilies/icon_lol.gif)
Now George, you just had to think that
when we talk about serious things. I do happen to know a former Rockette
![Razz :P](./images/smilies/icon_razz.gif)
![Very Happy :D](./images/smilies/icon_biggrin.gif)
John Hess
Past President 2018-2021
President 2016-2018, TIC170A
Director 2005-2014, TIC170A
N3833V Flying for Fun
'67 XLH 900 Harley Sportster
K3KNT
K3KNT
I thot thet's whut i wuz payed by awl yew guys so much to do....theenk!n3833v wrote:Now George, you just had to think thatwhen we talk about serious things. I do happen to know a former Rockette
Getting back to the original subject (about my 170 handling), I landed at Grawunder (06R) yesterday, it is 30 feet wide, normally not a huge deal but narrow enough to get your undivided attention, there is no way I would have landed there in the past. Before, even though I always strive to keep the airplane exactly on centerline, I could never trust the airplane to track where I wanted it, sometimes it would make an uncontrollable excursion of 10-15 feet. Now it tracks where I point it. Wheel landings which were always squirrely are now actually easier than the three point. I am digging on the new utility of my airplane!
If anyone is having trouble withn the ground handling I would sure recommend checking the alignment.
Now I wonder where I can find one of those Rockettes?
David
![Wink :wink:](./images/smilies/icon_wink.gif)
David
I've found the wheel alignment discussions very interesting. My 140 tires were getting old, wearing and needing replacement. The left side was wearing quite a bit on the inside, and the right side wearing on the inside but not anywhere near as much. I bought a set of Condors, same as the old ones, and a 10' long piece of 8" channel for a straight edge. Used the greased garbage bag method, though I think next time I'm going to try the newspaper method. I measured the toe and found both sides had 5/16" toe-out. the airplane always seemed to handle fine, no tendency to swerve or chase geese in the grass on either side of the runway. I figure that since the toe was the same amount of way out on both sides, it balanced things out. I adjusted the toe with the new tires to about 1/32" toe-in on each side. It should still handle good and the tires oughta wear better. Tire pressure wise, it's had between 32-35 psi in the mains since restoration last year. I've reduced that to 22 psi, 16 is the factory spec but I don't want to go there in one swoop. Now I just need the snow and hurricane winds to move on so I can see how she handles.
Reading through SLN-56 I'm curious about the admonition:
tye
I found that it would be impossible to reach any toe-in at all if the thick corner was always down and forward. To move the front of the wheel inboard the thick corner has to be in the back."In making the shim installation, it is very important that the shim be installed correctly, that is, with the thickest corner forward and down."
tye
