Good catch. Of course when I typed Major I was thinking in terms of what wasn't a minor repair. Of course a Major repair on an engine would not be an overhaul.gahorn wrote:My intent was to keep us from re-defining the terms.
We intentionally did not list all the requirements of an overhaul. We simply stated that once the inspections Thad planned to carry out where done, he was closer to an overhaul than not so why not complete the overhaul.gahorn wrote:Neither plan would meet the definition of " overhaul"...
gahorn wrote:...if the cylinders (or any other time-in-service component) was merely
inspected and not returned to overhauled condition.
Yes I agree the word overhauled is many things to many people and not understood by many. So there it is. What is overhauled condition? The word overhaul is not defined in FAR 1.1 how ever it is defined in FAR 43.2 Records of overhaul and rebuilding.gahorn wrote:One of the most common errors found in logbooks is the
confusion and mis-use of those terms. The vast majority of
engines returned to service after major teardown (despite the logbook
entries), are neither overhauls nor rebuilds...but instead are "repairs".
- § 43.2 Records of overhaul and rebuilding.
(a) No person may describe in any required maintenance entry or form an aircraft, airframe, aircraft engine, propeller, appliance, or component part as being overhauled unless—
(1) Using methods, techniques, and practices acceptable to the Administrator, it has been disassembled, cleaned, inspected, repaired as necessary, and reassembled; and
(2) It has been tested in accordance with approved standards and technical data, or in accordance with current standards and technical data acceptable to the Administrator, which have been developed and documented by the holder of the type certificate, supplemental type certificate, or a material, part, process, or appliance approval under part 21 of this chapter.
(b) No person may describe in any required maintenance entry or form an aircraft, airframe, aircraft engine, propeller, appliance, or component part as being rebuilt unless it has been disassembled, cleaned, inspected, repaired as necessary, reassembled, and tested to the same tolerances and limits as a new item, using either new parts or used parts that either conform to new part tolerances and limits or to approved oversized or undersized dimensions.
So a cylinder inspected and found not to have any defects outlined per the overhaul manual and also within the serviceable dimensions IS in overhauled condition. It requires no new parts or new tolerances.
So bottom line an overhaul is nothing more and nothing less than a Disassembly, Cleaning and Inspection (Chapter 10 OHM). Repair and Replacement (Chapter 11 OHM). Reassembly, Final Assembly, Timiing and Testing (Chapter 12).
Those parts that can not be repaired to at least serviceable limits or those parts required to be replaced by the manual are the only new parts required. Of these steps the testing is probably the one most flagrantly not followed. How many have a 4 bladed test club (not a flight propeller) and ground run the engine with no baffling installed?
The biggest misunderstanding with the word overhaul is folks think it means the engine or its part are new or like new. That can be pretty far from the truth. And log book entries don't help lots of times as the overhauler is not required to list the discrepancies found and how they were repaired or to what tolerances the components were found, possibly repaired to, and used. They are only required to say the engine was overhauled per the overhaul manual and that leaves some pretty wide latitude.
Here is a link to an excellent article I found on this subject: http://www.aviationpros.com/article/103 ... rhaul-myth
