1) if you need room in the back, take it out.
2) if you need to take more than one passenger, put it in.
There are a couple of errors that may be introduced due to poor-wording/syntax.wingnut wrote:My local FSDO (actually ONE person at this FSDO office) agrees with George. I copy and paste his reply here, and then I'll comment.
LIT FSDO reply:
"If the aircraft is operated FAR 91 the owner/operator is
allowed by FAR 43.3 (g) to perform preventative maintenance.
FAR 43 Appendix A (c)(15) "replacing seats". It allows for one seat
to be replaced with another. [Webster New World Dictionary of American
English]- [replacing: to provide a substitute or equitant for]. If the
FAA flight manual allows the pilot to change seating configuration by
removing seats that would be permissiable via the flight manual. The
preventative maintenance referred to above does not allow for the change
of configuration then operate the aircraft in the new configuration. It
allows one seat to be replaced with another, (seat swapping-replacing).
A FAR 91 pilot/owner who removes seats (change in configuration) dose so
contrary to the FARs.43.7 and others.
Any change to the empty weight by the removal of seats is defined in 43.
Appendix A (a) (xi) is a major alteration.
The FARs is clear and the highest order pertaining to this subject"
Well, my comment is this; "clear in the highest order" my a**. In describing the types of alterations that would be defined as major, Appendix A(a)(xi) says:
"Changes to the empty weight or empty balance which result in an increase in the maximum certificated weight or center of gravity limits of the aircraft"
This definition contrast greatly with the LIT FSDO's opinion that "Any change to the empty weight...."
I want some real answers, real regulatory information, not FSDO departmental policies or opinions.
Yea but would it be understandable?hilltop170 wrote:Someone should call the IRS and get their opinion. I'm sure they could give us a definite answer.
George is right here....the removal of seats, constitutes a change from the TCDS sheet.....It's as simple as that...voorheesh wrote:Unfortunately, George is just plain wrong here. The removal of the seat does not result in an increase in the maximum certificated weight or the center of gravity limits. It does not affect the structural strength, performance, or flight characteristics either. It is not a major alteration. Where are the IAs on this forum?? What a pilot does in loading the aircraft after the change is made and it is returned to service is completely irrelevant in this case. A pilot could load a 170 over weight, out of cg, with cargo unrestrained, or in excess of floor loading limits with or without the seat installed. Appendix A to part 43 is informational. It can not be enforced by itself. The information contained in Appendix A must be used with some other rule in Part 43 to be enforceable. Can you imagine an FAA attorney arguing to an NTSB law judge that the alleged violator illegally "removed" the seat which he was able to legally "replace"? Give me a break!! "Replacing" a seat clearly implies the acts of removing it. Is George telling us we need to get a mechanic to remove the seat before a pilot can replace it? That is absurd. The legitimate question in this thread: Is removal of the seat preventative MX which can be performed and returned to service by a pilot? Or is it an alteration (NOT A MAJOR ALTERATION) which must be performed by at least a mechanic? The boys on the West Coast are not going to take this sitting down! More later.
