Ok, folks...I am now going to use some CAPITAL letters to re-EMPHASISE what some of you... including you voorheesh... seem to forget AGAIN AND AGAIN! (I am getting tired of some of you crediting me or transferring the FAA-FSDO opinion to me. This has happened several times now in this discussion thread.)
voorheesh wrote:Unfortunately, George is just plain wrong here. ....
(It is not correct to lay fault upon me...when all I did was point out how poor syntax may be the cause of others incorrect interpretation of the rule. That rule is poorly written and I merely pointed it out.)
As for those who continually lay what they believe to be an incorrect interpretation upon ME...This is NOT MY OPINION. This is the FAA OPINION IN SAN ANTONIO, TEXAS and FT. Worth Texas, and apparently LITTLE ROCK, ARK. and perhaps others !! GET IT? HUH?? (shouting at you guys now: )
GET IT??? I am merely reporting their position and re-telling their explanations as to how they arrived at those positions.
Voorheesh: Those FSDO's apparently interpret the rule LITERALLY when they read the word "replacing". (and voorheesh, you are someone who has on prior occasions suggested that FAR's be read plainly....and I do understand it when those FSDO's want to read that word "replacing" as being pretty PLAIN)....
It's some of you guys out there on the left-coast who seem to think that "replace" actually means something else such as "remove" or "substitute" or "install". I don't have that particular version of Webster's at my disposal and it doesn't seem to be at the bookstore either.
voorheesh wrote:... Can you tell us the difference between removing the parking brake mechanism and removing the rear seat? Could you point out where in the C-170 TCDS that the rear seat is mentioned? ....
Here we go again... it's been said before, but I'll do it yet again: Pull out the TCDS.
READ the DESCRIPTION of the airplane, where on page 2 it states:
"No. of Seats 4 (2 at +36), (2 at +70)"
It doesn't get any plainer than that.
Now, it's your turn. Show me where the parking brake is mentioned in the TCDS.
Here's a copy:
A-799 Rev. 54.pdf
I agree with those FSDO's in TX and AR only in the actual wording used in that rule. It certainly does say "REPLACING". I have repeatedly....REPEATEDLY... (but some of you are either disregarding the several times I've stated that here...or you are just recently joining the conversation without reading the entire thread...) I have repeatedly pointed out that in my personal opinion the removal of the rear seat SHOULD be a minor matter and pilots should be allowed to remove the seat and operate with it removed. The problem is...that's not what the rule says.
Now... as for the recent little side-show regarding para (xi): If you guys will GO BACK and RE-READ what I originally posted.... you will see that I SPECIFICALLY said that there was a POSSIBLE error in SYNTAX and that SOME folks MAY read that paragraph to mean three different conditions MAY apply that would make the removal of the seat a major alteration. That was not an attempt by me to alter the wording in the rule...it was merely pointing out that the sentence DOES use the word "or" between each of the conditions it claims affects the level of alteration.
And AGAIN... this is only a discussion among friends who are desireous of getting FAA to come up with a uniform interpretation of this matter. I invite anyone and everyone to provide a link to their local FSDO to this discussion and invite them to pursue the question with FAA-OKC.
Meanwhile, when a participant at these forums ask the question "what is necessary to remove the rear seat"... it is NOT CORRECT to advise them to simply do so and make a note of it in their logs until ALL FSDO's interpret the rule in the same way. As long as SOME FAA types think it's a violation to remove it... then it's necessary to comply with their interpretation if you wish to avoid further trouble. And that's the way I will continue to advise folks until a uniform/universally-agreeable interpretation is arrived at by FAA.
What you do with that information is entirely up to you.
