Oil Sump Corrosion
spduffee
Re: Oil Sump Corrosion
Post by spduffee »
"We'll see how long their repair lasts. I'm betting it will."
Hey Richard,
That was 2006. What empirical data have you got to show after 6 or 7 years? Any leaks? One of the first replies was from Bruce F who warned me not to go the welding route because of the lack of options (like ZERO) after a welding fail. I am worried about the position of the corrosion (very near to the vertical riser for the carb mount) and have doubts that it can be welded successfully; but everyone else swears by DivCo and that they can do it. I like the bolt and plug idea, but again, too close to the vertical riser for comfort. After all the "little things" that I have discovered that have corroded, worn out or are just wrong, I really feel like opening up shop on producing classic aircraft restoration parts. Any investors reading this?
N5448C -1950 170-A
Shawn-
No evidence of failure has been detected with the repair on my oil sump in 6 years. If I had it to do over again, I would send it up to O.A.E. and let them repair it. If they send it back as unrepairable with their process, then I would send it to Divco.
The epoxy repair corrosion-protects the oil sump from further corrosion, just welding does not stop the corrosion, it will come back.
Call O.A.E and ask them how the older repairs are holding up.
edbooth
Post by edbooth »
If interested, I have a three bolt oil sump with no corrosion and no repairs. I had always assumed the three bolt was for a C-125 engine. :?
Richard, when you had your sump repaired 6 years ago, do you remember if their charge for repairs varies based on the degree of corrosion or is/was it a flat charge plus shipping? Just curious what the cost might be for those kind of repairs.
Frank-
I can't remember how they charged, they would have to be called to see what their current repairs would cost. I aslo never saw the finished repair before it was installed, or I would have taken a picture. The engine guy had it buttoned up before I got there but he said it looked good.
spduffee
Post by spduffee »
I'll call them tomorrow and post any updates for anyone interested. I assume they'll say they can't give a quote without seeing the part _ DivCo said the same. I'd like to get the sump off to one or the other tomorrow, or at least this coming week. I have a bad feeling I'm going to miss a lot of the early spring flying :evil:
N5448C -1950 170-A
T. C. Downey
Post by T. C. Downey »
I completed a overhaul on a 0-300-A with a very bad sump, it was sent to AOE, it came back repaired, and it looked great, and I got the same story that has been posted here. They do have a STC in Canada, but we can get a field approval in the US if the A&P needs one.
the cost was 450.00
Too bad we can't post pictures directly to the post content here.
spduffee
Post by spduffee »
edbooth wrote:If interested, I have a three bolt oil sump with no corrosion and no repairs. I had always assumed the three bolt was for a C-125 engine. :?
I am interested. Please PM me. Thanks.
N5448C -1950 170-A
Pictures are very easy to post.
Un-check Disable BBCode
Click on Upload Attachment and just follow the prompts.
Only TIC170A Members are allowed to directly post pictures, however you may post at photobucket (etc) and link to them.
(Spam and inappropriate pics controls)
T. C. Downey
I should raise the priority on joining the club again.
Tom, I agree.
YOu are a fantastic resource for the entire aviation community (even though you and I don't always agree on everything...I welcome you to re-join the Association to which you belonged for so long and to which you have contributed so much. Do I need to loan you the first year's dues?) :twisted:
T. C. Downey
gahorn wrote:Tom, I agree.
George I seldom agree with anyone on every thing.
BUT.. the only advantage to joining for me, would be to post pictures here, Yes I know it is a great club, well run, and well worth the money. as long as I'm welcome to stick my $.02 in here I'm good with that for now.
OKay, Tom. (But please don't be offended if/when we delete or move any adverts.) :wink:
hilltop170 wrote:I asked if O.A.E. would clean and apply the paint to a good oil pan to inhibit corrosion. He said they do that but he has never seen one without some corrosion and no matter how little, their repair stops the corrosion and protects the metal all around the area.
I recently attended an IA renewal seminar in which Loren Lemen gave an interesting talk of what they are doing at Ly-Con in Visalia, CA. He comes there after working for many years as at TCM. I asked him if they could repair O-300 sumps and he said no but what some guys do is paint the inside of the sump with Glyptal. Anybody ever used this paint? I wonder if this is the paint that O.A.E. uses?
