fuel selector operation 1948 170
buenoav
Post by buenoav »
The one I have is valve handle only (no Pointer). Left tank mark is on right side of plate, right on left side of plate, both on bottom, and off on top. They appear to opperate correctly, but to get over Tabs (stops) the lever had to be pulled up to switch functions. Is this correct?
Any help or guidance will be appreciated. ASAP I hope. Thanks Neil
Re: fuel selector operation 1948 170
What model? Sounds like you might have a '48.
n3833v
Post by n3833v »
My 48 has a stop pin at top for OFF, then no tabs or stops for the rest of the settings with again, BOTH at bottom. The lever is connected to the valve at the firewall with a long shaft.
John Hess
Past President 2018-2021
President 2016-2018, TIC170A
Director 2005-2014, TIC170A
N3833V Flying for Fun
'67 XLH 900 Harley Sportster
K3KNT
