Will a headliner from a C-175 fit a 170 ?
If we use the patterns from a 175 head liner what modifications will we need to make?
Interiors (Headliner differences)
Re: Interiors
If memory serves you are installing this in a 48. 48 and model headliners have the inspection zipper running dow the center fron to back to facilitate cable inspection. B models and I assume the 175 have the zipper running side to side. Other than that I'd bet they are the same but I've never studied the 175.
- Poncho73
Re: Interiors
I'm doing the headliner in my 48 now. As you mention the 48 zipper runs down the centre. I bought a new liner from Airtex, and bought the wool type. I believe the 175 like the later 170's has the square style aft windows so it may be an issue if there is limited material. The 48 headliner wires are also a little different. My 48 doesn't have the speaker, I have no idea what the 175 has, it's been 30 years since I even been in our flown a 175.Bruce Fenstermacher wrote:If memory serves you are installing this in a 48. 48 and model headliners have the inspection zipper running dow the center fron to back to facilitate cable inspection. B models and I assume the 175 have the zipper running side to side. Other than that I'd bet they are the same but I've never studied the 175.
